Reid Welch
A January portrait of a Currie Mongoose cruiser e-bike
Has short 140mm cranks suited to a child's leg-length
and a 44T chainwheel = a poor set-up.
New, longer cranks arrived in today's mail.
Hooray, I learn to use a crank puller.
I decided to open the bottom bracket to add grease.
What grease? Why this thing contains nothing but dried sludge and sand and metal shavings; the latter from the factory.
It's a dirty business building bikes to a price point.
If all roads lead to Rome, the same is true in this bike at least:
All tubes that intersect with this bottom bracket have exit holes in them.
So any water or rust or filth that shakes or washes down ends in the bearings of the bottom bracket.
I will fix this. Now to run get a tube of waterproof marine grease;
all I have here is synthetic moly-bearing wheel bearing grease.
That won't do for this bottom bracket because moly turns abrasive in the presence of moisture.
See too: there are no seals at the spindle's exit points.
I won't fix that with felt seals (like we did in the Model T's heyday);
I should make felt seals but I think for now I'll just make a small weep hole in the bottom of the bottom bracket.
By that hole I can inject fresh grease from time to time to eject any water that may have started to ingress at the spindle ends.
This will also push out grit.
OK, I'll show the finished Crank Conversion when it's done.
All owners of cheap bikes with the cup and cone bearing system may profit by doing this sort of maintenance early
before it is toooooo late.
crunch!
crunch!
