hmmmniek
- Joined
- May 5, 2022
- Messages
- 14
TLDR: Two times, my custom built bike suddenly unintentionally accelerated. Is this a common issue? What is the best way to move forward with this issue?
A while ago I bought this kit to build an ebike. I got everything up and running perfectly.
https://www.amazon.com/gp/product/B08R3TNCKT/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
The only complaint I had about this system, is that there is not much of a configurable "acceleration curve", if you give it throttle, it will just dump a crazy amount of power into the motor to get up to speed, so you have to be very careful.
Although this is definitely something you can get used to. But after about in total 80 or so km of riding on this thing, suddenly it would open throttle completely. Luckily I was able to keep control of the bike, and I also build in an easily reachable big battery cut-off switch which I could quickly use to save myself from... I don't know what would have happened if I didn't have that.
After some deep breaths, I turned everything back on again, and it all seemed to work fine again. I continued to use the bike for hundreds more kilometers, and even started doubting myself if this even really happened, maybe I just slipped my thumb on the throttle without realizing it? Maybe it was just my own fault?
Until yesterday, I was going about 20km/h, and mildly accelerating with the intent to reach 40km/h, when suddenly it went full open throttle again! Quickly grabbing the brakes while keeping the bike under control, and quickly after I managed to use the battery cut-off switch again. Luckily to me again, I had plenty of space to regain control.
It seems like someone else in the amazon reviews also had this problem:
https://www.amazon.com/gp/customer-reviews/R14553HIC6HWS8/ref=cm_cr_arp_d_rvw_ttl?ie=UTF8&ASIN=B08R3TNCKT
In that review, they say the problem seems to be the controller, which makes sense to me.
I tried contacting the seller, they say they have not encountered this problem before. I asked if there was some way to extract logging data, but have not received response back from them on that yet.
I rode over 300km on this bike so far, and the problem occurred twice. Which is a bit scary.
My question(s) which I would love your opinions on is:
- Is this a problem which happens more often with electronic vehicles?
- Is there any known common cause to problems like this?
- Any suggestion on how to move forward?
- Should I just bite the bullet and buy a new controller?
- If so, which one would you suggest for a 72v, 3000w peak system (I do have some dimensions constraints, the controller cant be wider than 110mm)
