Suggestions to Harden Plastic Enclosure
I am using a modified tupperware container to house my electronics. Photos here for reference: https://www.flickr.com/photos/bensacks/sets/72157656673787494
The plastic tupperware has cracked on one corner and side. I am considering options to reinforce it. Beyond typical epoxy in the cracks, can anyone suggest a method to harden the entire enclosure? I am thinking of an epoxy type coating I can cover the entire piece in or perhaps some sort of carbon fiber or thin material that can be flexibly applied before it hardens.
Any tips appreciated. Thanks!
The polyester resin used for fiberglas is good, you don't actually need the fiberglas itself though it will make it stronger. But tupperware itself doesn't allow things to adhere well. Epoxy will work better than polyester or vinylester, but I don't think it's the answer. If you try it I suggest putting it on the inside rather than the outside.
What is determined to stick to ANYTHING? Urethane. Gorilla glue, for example.
But my real advice is to look beyond tupperware. I don't think you'll come up with anything that lasts.
You might try using the tupperware shape as a mold master to create a new casing. https://www.smooth-on.com/ A process similar to this would probably give you what you want. https://www.smooth-on.com/tutorials/2-piece-core-mold-concrete-urn-example/
What about 3D printing a custom enclosure out of ABS?
Is a kit like this what is being referred to? https://www.amazon.com/3M-420-Fiberglass-Resin-Repair/dp/B000BO9NOO
I'm sure it's what they mean, if only the laminate wouldn't delaminate.
You'll have better luck with:
http://www.westsystem.com/specialty-epoxies/gflex-650-toughened-epoxy/
http://www.easycomposites.co.uk/#!/resin-gel-silicone-adhesive/epoxy-resin/EL2-epoxy-laminating-resin.html
If it's actually tupperware (or one of the many clones), there are no adhesives that will bond to it, as it is probably made of HDPE (you can verify this by looking up the recycling number in the triangle on the bottom of the container). The only method of repair of it's actual plastic is to melt it back together. Too high a temperature will make it more fragile, so a soldering iron or similar isn't recommended.
You can, however, use the tupperware as a mold for the fiberglass/cloth replacement.
Storage containers UV out and get brittle so the trick is keeping sunlight off of them. I would try some of the flex seal spray... They sell it under different names at Home Depot etc. It's like spray on rubber and is insanely sticky.
Whatever you do though with sealed enclosures, made sure it's not letting water in where the wires go, and then trapping it in there.
As I noted above, it won't bond with the plastic (it's probably HDPE), though it may appear to stick to it at first (many things do, but they all come off once cured).
This page has some info on how one might be able to bond stuff to it with industrial adhesives, but it doesn't seem worth it for this purpose.
http://www.permabond.com/2015/03/31/prepare-bond-polyethylene/
