bowlofsalad
What is the down side to too much suspension?
You can make suspension shocks quite firm, and mine can even be locked out. If there's not enough pressure then they become spongy or boaty - like a car with bad shocks - and create difficult handling conditions. I particularly dislike low pressure in the front shock which causes nose-diving when you hit the brakes. Too low pressure on the rear shock can lead to bottoming-out.bowlofsalad said:What is the down side to too much suspension?
Ykick said:There's also a great amount of difference between suspension component quality. Good quality air/oil/gas properly valved components shouldn't even be mentioned in the same sentence as pogo spring Wallybike suspensions. Night and day difference in performance and the only legit argument for the cheap stuff is that it "might" be better than nothing. It also may be worse....
Nothing personal nep.neptronix said:Can we lay off the ad hominem attacks?
neptronix said:Ykick said:There's also a great amount of difference between suspension component quality. Good quality air/oil/gas properly valved components shouldn't even be mentioned in the same sentence as pogo spring Wallybike suspensions. Night and day difference in performance and the only legit argument for the cheap stuff is that it "might" be better than nothing. It also may be worse....
A walmart bike with a spring out back is definitely better than nothing. Many times more comfortable than my more expensive Trek 4500 hardtail with a slightly above bottom grade RST front fork ( GILA model, i think ).
The big difference is that i can put a better rear shock on the walmart bike, but i can't put one on the expensive hardtail.
The genesis bike with a fox shock rides great.
rp3 said:Nice vids Chalo. :wink: An F1 car could be driven as a rally car, but would you really want to? Would it be as good a s a dedicated rally car?
full-throttle said:Not sure why you brought all those videos though, especially track racing. What does it have to do with ebikes??
Here is what those guys would be riding if they had suspension
neptronix said:Chalo, do you own an ebike?
neptronix said:Hm, so a 24 pound motor and lead acid don't bug you, but a few extra pounds of suspension are just a big no-no!
I don't get you, dude. Not for a second :lol:
neptronix said:What i get out of suspension is less pain, and less of a feeling that i'm riding during an earthquake as my bike goes over the cracked, potholed southwest pavement. kind of a bonus to me. Well worth the 3-5 pounds.
It is even a rough ride out if you drive an econobox car like i do.
