safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Use in current measuring
A shunt can also be used to measure current. In this case a resistor of accurately-known resistance, the shunt, is placed in series so that all the current to be measured will flow through it. Since the resistance is known, by measuring the voltage drop across it, one can calculate the current flowing.
In order not to disrupt the circuit, the resistance of the shunt is normally very small. Shunts are rated by maximum current and voltage drop at that current, for example, a 500 A/50 mV shunt would have a maximum allowable current of 500 amps and at that current the voltage drop would be 50 millivolts. By convention, most shunts are designed to drop 50 mV when operating at their full rated current and most "ammeters" are actually designed as voltmeters that reach full-scale deflection at 50 mV.
If the current being measured is also at a high voltage potential this voltage will be present in the enclosure containing the reading instrument. Sometimes, the shunt is inserted in the return leg (low voltage side) to avoid this problem. Another solution is to use a Hall effect (non-contact) current sensor instead of a shunt.
So the idea would be to attach a simple LED to the shunt and you would know while riding that if it glowed really bright that you are using a lot of current and need to either back off the throttle or downshift. (depending on your machines abilities) You might also decide to just allow the high current usage in cases like climbing a steep hill. After all, the actual number of amps doesn't really matter if you already know what your controllers current limit is, so all you care about is what percentage of the limit that is being used. Full brightness means the full limit, partial brightness means less than the limit.
Out of the corner of your eye you would know exactly what was going on..
