Matt Gruber said:
Tip: to make a $2.99 DVM more ev friendly, solder a short piece of 8 10 or 12 AWG directly on the internal shunt.it can read to 50a(or whatever) instead of just 10-20a. Now, that's a minimal ammeter for $3.
Calibrate the shunt just like with a controller.
aaaaxe-celent!
I got a half dozen of these DVM's for twenty bucks precisely for this purpose, instrumentation on my ebike. 'Calibeur' moulded into the probes is the only name on it anywhere, if anyone has any info on what the lone internal pot adjust does. It may not be the simplest, but by far cheaper then anything you can build yourself. I mean you can't even buy replacement test leads at that price. :?
Care to elaborate on the calibration procedure. The max range on this meter is 10A, so a parallel shunt would have to be 1/10th or is it 1/9th the resistance of the existing shunt to give a 100A range?
****i JUST DID A 4x SHUNT MOD (scrap wire in parallel w/shunt), 4 AMPS INDICATED IS REALLY 16. *******
The A/D is a black blob mounted in behind the LCD. It's looking good that I may be able to cut back the PCB to eliminate the big rotary knob. **********8The goal is to wind up with dedicated single range ammeters & ESV that wouldn't be much bigger than just the readout mounted in a suitably sized enclosure.*******
GREAT IDEA!
Excellent tip & recommend everyone do this. It's basic metering that should be standard & at this kind of price point I fail to understand why it isn't.
