Safe's quote= But what I'm trying to figure out is why it's impossible to get a 2 Volt LED to run off of a "shunt like" device.
part of the answer to this question that has to do with the fact that an led is a band gap device. in a normal light bulb a tiny bit of voltage will force a tiny bit of current and it will light up just a little. of course a light bulb cannot be used with a shunt because the low impedance of the light bulb would cause a big error, and because it takes too much voltage to run a light bulb.
in a band gap device there is a wall across which the carriers cannot jump until they achieve an electrical potential higher than the other side of the wall by the band gap. a regular diode has a gap of a volt or so, a schottky diode .5v, and zeners have a wide range of voltage. the point here is that you cannot get current to flow through an LED until you exceed the band gap. There are LEDs with a gap of 1.1v, but that is still really too much of a shunt to introduce into your system. you would not want to throw away a volt to measure current, and the LED would not start to light until the drop across the shunt is over 1.1v.
When the current increases so that the voltage across your shunt would get a bit higher, there is no mechanism to limit the current through the LED and it would quickly burn out. For this reason, you need a current limiting stage or resistor in series with the LED. When you calculate the current in an LED, you use Ohm's law, but you have to subtract out the band gap voltage when there is a semiconductor involved.
For example, let's say you want the LED to get 10 ma when the voltage hits 5v, and you are using a 2V LED. I=E/R so .010A=(5V-2V)/R 1/R=.01/3 R=333 ohms. The resistor does nothing until the voltage exceeds 2V (except for very small leakage current that does not result in any light). Once the voltage exceeds 2V (or whatever the LED voltage) the resistor will limit the current.
it is possible that at high current level you could have enough voltage from one end of your battery cable to the other to light an LED. You can find out by putting your meter on the positive battery terminal and the positive input to the controller and measuring the voltage when you feed power to the motor. If you see more than 1.1v your idea of using an LED as a simple ammeter could work, and this will be an example that might help understand current flow in a semiconductor circuit.
You only need a very small wire to the LED from the ends of the positive battery cable. you are in effect using the battery cable as the shunt. the small current used by the LED will not load down the shunt or require wire any larger than the smallest you have. #28 would be adequate. When the voltage drop in the battery cable is less than the band gap of the diode, only the leakage current will flow through the small wire, and almost all the current will go through the battery cable. Once the voltage drop exceeds the LED drop, current will start to flow through the LED, only a few milliamps at first, but as the voltage rises a few tenths of a volt the current will climb quickly without a limiting resistor and burn out the diode.
If you measured 2V drop in your battery cable at maximum current, and you have a diode with 1.1v drop, you will want the diode to be bright at 2v so if we let it have 20 ma that will be 20ma. through r ohms with .9v or
R=E/I R=.9/.02 R=45 ohms. 47 ohms is the standard value so if there is 2v drop in your cable that could make your meter LED idea work. It would also mean your cable is not heavy enough. This example was more to help understand what is happening than to make it work.
A semiconductor is a material like silicon or germanium that can be "doped" with other chemicals so that current flow can be controlled by current or voltage control. A diode is the simplest semiconductor device, and a LED is a diode that liberates photons of visible light when the carriers jump across the band gap.
-bob
Do you see the theory? (or the misunderstanding on my part?)
It "should" flood if the analogy is good and there "should" be some kind of "trickle" current that wants to find a "less crowded" path.
Aren't there physics to wires that are already loaded? (that are different than a wire that is unloaded)
What's a semi-conductor?
[/b][/color][/size][/quote]
