kudos
Of all the issues the diy ebike convertor faces, where to place and mount the batteries I think is the hardest.
If you only need a small battery then it's no problem, they can be popped in a bag behind your saddle or plenty of other places.
If you require a larger battery though suddenly you're faced with having an ugly heavy rear pannier wrecking your handling.
Or you could use a frame bag which are handy but arguably ruin the look of your bike.
Some people with triple-crown forks have fabbed mounts to attach to the front of the bike but again ruin the bike lines.
I'm surprised with all the talent on these forums no one has come up with a ready to go battery case/mount that doesn't look like a elephant strapped to cat.
I'd like to have a unit that attaches under the down tube near the bottom bracket.
There's enough width there between the pedal cranks, the centre of gravity would be low and in the middle for good handling and it could be shaped with a curve so as not to ruin the lines of the bike.
One end could hook over/around the bottom bracket and the other attach to the downtube.
Does anything like this already exist?
Kudos
Kudos
