Jay64
Yeah, I had heard that it quits out pretty fast, but it was showing red when I first plugged it in, and then it was green when I checked back in about 6 hours later. I guess I should go and buy myself another volt meter, mine blew the fuse and it was one of the cheap ones that costs less then the fuse. I know I need to get a digital one that is a lot better then the one I had, but I'm waiting to start work next week to get more money and I get a 10% discount. But I think I can't wait that long, I need to check and see if the battery pack charged up or not. I checked the fuse on the battery pack and it was good. I looked in the controller box to see if there were any loose connections or a fuse of some sort in there. It all looked good. I read through the manual, and suprisingly there is no start proceedure listed and the only troubleshooting guide that it gives is for the actual mechanical parts of the bicycle, nothing on the electrical system or the motor.
So Albie, what did you do to fix the situation? Did you just use a different battery pack or did you use a different brand charger that worked with that battery pack? I have a 12v charger, but I think I would have to take the pack apart to use that since it is a 24v pack, or am I mistaken on that?
