safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Throttle and Current Limit Theory
In a controller there are two parameters that effect the behavior of the motors powerband. One parameter is the throttle which sets an absolute cap on the duty cycle, but makes no attempt to tell the controller to lower the current. The other parameter is the "Current Limit" that a controller is set to stay within so as to not overheat the motor. These two parameters have VERY different behavior.
First let me begin with a review of exactly what a throttle does. The duty cycle is the percentage of time that a pulse is allowed to remain open within the periodic cycle that the controller cycles through. The typical frequency of the controller seems to be around 20 kHz and so the period is about 20 milliseconds in length. As the throttle is reduced the duty cycle is limited so that it cannot rise above the proportion of the throttle setting. So the effect on a motor looks like the charts below. Notice how at 50% the powerband is effectively unchanged except it's basically "chopped" off from it's high rpms. At below 50% you see things really start to fall apart.
