[/img]Hi. Had a bit of an issue with my tongsheng tsdz2 in that where the xh18 display lead joins the lead to the motor 2 pins broke off. Motor Was still working but display didn't show! Much. Would turn on but couldnt change speed etc. Well decided to try a new vlcd6 display. I removed the broken pins from the female connector going to the motor.joined it up but just showing all 8's on the display. Won't turn on or off just turns on with battery on. Can I replace the cable to the motor and if so where could I get this lead? I had to cut some of the plastic around the Fermale connector. I think it's dirty connections or pins maybe touching each other.. Thanks
