About throttle.
If I set min on 0 - in the technical I got value 35 (motor is going without pushing the throttle). If set 35 - I got value 9 in technical, if set 40 - value 3 in technical, if set 45 - 0 and working well. All without pushing the throttle.
It seems that the value in the technical menu is depends on min value setted in temperature menu. I haven't checked what value I get after pressing the throttle all the way down with the min. setting of 45. Will it be 255? I'll check.
Overall, the throttle works at full range, so it's a nice improvement. Be careful when setting the parameters – if setting them to 0 - after activating off-road mode, the bike propels itself. I saved myself by switching to street mode.
edit:
If I set the max value to 255, I get 163 in the tech menu with the throttle fully depressed. After changing the max value to 200, I get 222 in the tech menu with the throttle fully depressed.
