So probably you are looking at the "created" date and not the "modified" date. That explains why timestamp does not change.config.hex on my PC is same date, on my laptop always 25.06.2026 , but it is created and has the changed settings, so it seems fine.
On some TSDZ8, the values provided by the torque sensor varies with the position of the pedal. That is the reason why I recommend to get the value for different pedal positions (with no weight on the pedal) and to use the highest value found and even adding some margin to it. It is explained in the readme.Hello,
I've had my TSDZ98 (750w) mid drive motor for a while now and its been functioning great on my bike. The only issue I had with it was that the PAS even at level 5 wasnt strong enough to feel effortless for me so I wanted to alter the software to increase it. So I followed the guide from mstrens on github and everything was working fine until I measured the ADC minimum and max and input it into the Java configurator and flashed it to my bike, which gave me the Error 02 constantly on the display when I turned it on. So I'm stuck at stage 5. My Display is the EKD01 and my ADC minimum values is between 118-119 on the display and the max is 305 when im on the pedals.
Any help would be appreciated, thanks.
Thanks for the reply, I spun the pedals backwards and still got the 11.4 (114 in software) figure no matter what. I eventually set it to 150 in the java configuration and error 02 went away. But now it seems to use way more power for an equivalent effort compared to the stock firmware so I might just keep the powallon firmware as that has the PAS improvement I want with goof efficiency.On some TSDZ8, the values provided by the torque sensor varies with the position of the pedal. That is the reason why I recommend to get the value for different pedal positions (with no weight on the pedal) and to use the highest value found and even adding some margin to it. It is explained in the readme.
Hi, I have the exact same problem as you. I have the TSDZ8 with OSF_TSDZ8_860C_KATANA_2_V00_01.35 and the SW102 with sw102-full-0.19.17.About throttle.
If I set min on 0 - in the technical I got value 35 (motor is going without pushing the throttle). If set 35 - I got value 9 in technical, if set 40 - value 3 in technical, if set 45 - 0 and working well. All without pushing the throttle.
It seems that the value in the technical menu is depends on min value setted in temperature menu. I haven't checked what value I get after pressing the throttle all the way down with the min. setting of 45. Will it be 255? I'll check.
Overall, the throttle works at full range, so it's a nice improvement. Be careful when setting the parameters – if setting them to 0 - after activating off-road mode, the bike propels itself. I saved myself by switching to street mode.
edit:
If I set the max value to 255, I get 163 in the tech menu with the throttle fully depressed. After changing the max value to 200, I get 222 in the tech menu with the throttle fully depressed.
Kuck dir das an da geht es um die Probleme der menschlichen watthello. I have TSDZ8 with 860C OSF - i programmed it about 1year ago and I think I have Katana hex (0.33) installed now. Is the newest Spider 02.04 better? Im looking for best soft and settings for eMTB - im looking for natural felling - ,,Bosch like".
When I spin pedals without chain I have about 210 Torque ADC offset and Toque ADC Max 420. I have Calibration ,,disabled" - do I have to enable it? How to calibrate HUMAN POWER right? I see that it is showing to much power (i have compare with two indoor trainers).
Je ne pense pas que ce soit possible car il y a 2 systèmes de roue libres à l'intérieur du moteur (un pour le pédalier et un pour le couple exercé par le moteur)Bonjour, je souhaite installer un moteur TSDZ8 sur un tandem. La transmission étant à gauche, pensez-vous qu'il soit possible de modifier le câblage pour que le moteur tourne en sens inverse ? Merci.
Bin mir nicht sicher, ob meine Firmware bei ihnen gut funktioniert.Haben Sie eine Hex-Datei mit dieser Verbesserung?
Post in thread 'TSDZ8 OSF (open source firmware)' TSDZ8 OSF (open source firmware)My values: offset 215, max adc 420, weight 25 and 341 torque with weight - with your formula it is excatly same as OSF calculate - 43.
I see that <150 Human Power maybe it could be accurate but >150 it is too low.
I don’t know how to make it. Could you send me ready hex file for 860C?Post in thread 'TSDZ8 OSF (open source firmware)' TSDZ8 OSF (open source firmware)
Habe die eine meiner firmware.hex getestet ?
Hier der link der 2 firmware.hex, es dind zwei verschiedene faktor 2 und faktor 3,5 Download - Google DriveI don’t know how to make it. Could you send me ready hex file for 860C?
i wrote dm to youHier der link der 2 firmware.hex, es dind zwei verschiedene faktor 2 und faktor 3,5 Download - Google Drive
With VLCD5 you can use the version from this link :Hello, is there any OSF version for TSDZ8 (750W) with factory display VLCD5 (4 assistance levels)?
I have 2200 km on TSDZ8 with stock firmware 02082024, but I am not satisfied with power distribution between levels.
If not, which is the most affordable 5 assist level display that supports OSF? I would not invest too much money in it, bike is rather old now...
Is there a newer factory firmware available maybe? I have Jlink programmer.
