markobetti
- Joined
- Jul 16, 2009
- Messages
- 620
at the first picture take a look at the fork... its not noleen or girvin and theres actually no suspension there .. but its stylish
AussieJester said:p.s Matt.P dunno if your interested but Mick said these come through his work often
if you need a new fully adjustable bench he said he can get you one for nix they
go into his works scrap metal bin![]()
1000w said:AussieJester said:p.s Matt.P dunno if your interested but Mick said these come through his work often
That's awesome Kim, I would love one thankyou very much.
Cheers,
Matt.P.
And some even have their battery mounted with the motor in the wheel; these batteries I've got came from them.recumpence said:I have seen wheelchairs (OK, just one) that had hub motors. I think some are designed that way.
That looks very similar to the frame design I was after that I photoshopped early in this thread. 8)AussieJester said:
That's what I found with my tubing with 1.2mm wall thickness, so I'm using your solution. Damn, you'll have your second build finished before I get my first one done. Oh wellAussieJester said:I have had a bit of a crap time getting the front downtube bent to my liking, finally
got it 'right' this arvo required sleeving and joining two bends...same
deal as the blue cruiser. The bender dents the tubing worse than the thicker tubing
used on the cruiser too, shall smear some bondo over it be fine
