j3tch1u
great job! the bike looks stunning..and you've got just enough space for a third motor!
quad motor quadangle anyone?
j3tch1u said:you've got just enough space for a third motor!
recumpence said:I nearly finished my Lipo mount. It has a sort of wave look. That material is a proprietary 7mm thick CF plywood laminate I have made special for my RC heli main keels.
That material is super strong and ultra light.
Matt
MitchJi said:Seems like perfect material for battery boxes. Are sheets available for purchase?
recumpence said:Oh, that reminds me, the bike weighs in at an even 45 pounds with all equipment! Hmm, 3 pounds per horsepower!
Matt
Miles said:MitchJi said:Seems like perfect material for battery boxes. Are sheets available for purchase?
See here, Mitch:
http://www.dragonplate.com/ecart/categories.asp?cID=3
recumpence said:Dragon Plate is the most expensive CF place on the planet! They are asking $30US for 1/4 a square foot. I pay (or I did a year ago when I bought this panel) $170 US for 3 square feet.
Oh, you can cut CF with a carbide tipped table saw blade. You cannot cut it with a sabre saw. The blade will dull in about 6 inches of cut.
Matt
swbluto said:Status update?
mud2005 said:Hi Matt, I was wondering how many teeth are on the drive sprocket? what do you think is the lowest number of teeth that can handle the high rpm without being to loud? I have a 16T on my motor and I need to go smaller, but I'm not sure how small.
edit: I just realized your running 6-turn motors(225Kv) at 48 volt for ~10,800rpm. seems like high rpm for chain, is there a reason you didn't use belt drive for the first reduction?
Higher RPM with a lower reduction gives much more power.
