recumpence said:
I don't mean to argue with you, but it would not be $2000. It would be $400 for the caps I would use (the C size cells). You are looking at the wrong cells.
Don't hesitate to argue with me Matt
- i like your opinions.
But i'm sure i'm looking at the right cells for your needs.
recumpence said:
Also, you are calculating voltage drop of the caps without any battery at all, merely capacitors alone. All I am looking for is a helping boost, not to power the whole bike. They are also very light weight for their size.
Once again i'm sure you are wrong. 80 A load is a mean value. It is 160 at begining and zero at the end (8 seconds later).
You now have heavy load 120+ A at accelerations, so i'm sure after such pricy upgrade you should have 160 A available at least.
But if you still sure i'm wrong, so show us your calculations - and related explanations - Matt.
recumpence said:
My lipo pack would still be putting out the majority of the current the motor would be pulling. The caps would merely help out with the peaks.
If this would be the case, than ESC would see majority of the voltage sag.
If you want eliminate majority of the sag at peaks than supercaps cannot merely help out - they should help out as much as they can. This is what you paying for at least.
recumpence said:
Again, I am not married to the ideA. I am just intrigued by it. Lastly, I cannot run 50% more voltage. My controller won't hanle it, nor would my motor. My efficiency is decent for the power output I have and the weight. I am just sort of thinkihng out loud with this. I have seen these used in car and motorcycle applications as an added boost to eliminate voltage drop under load with great success.
Matt
I'm also not married with ideas
. But i'm sure you need much more than 40V (at ESC) if you need
6kW power out or even more .
If your controller won't handle 50% more so try 35% more.
If your motor won't handle 50% at heavy load than you should consider to use another one.
High efficiency and high rpm limit is what you paying for.
If motor Rm hot is close to 80 mohm than you need much more than 40V at 200 A load if you need 6 kW power out.
Best regards
