MitchJi said:
Hi,
swbluto said:
Capacitors can dump all their power (current) in seconds so power with caps isn't an issue. Part of EEstors method to increase capacity is to store at at high voltage (which requires a breakthrough insulator) so high voltage (if desired) with high amps with no voltage drop is the promise. The issue with caps is energy capacity which Eestor claims to have solved (according to their claims much better than lipo). Also life rated in 10's of k's.
Yeah it looks as though there is a sweet spot in the higher primary voltage of the actual caps coupled with their ability to dump all their power. If people dont know already these are voltage driven and the voltage is converted into amps by the regulator that keeps it at say 24v.. The actual farad of these ultra caps is similar to low energy ultra caps, at 30 farad. My 2.5v @ 55 farad maxwell caps have more capacity than these. However the eestore patent store 3500v at 30 farad and regulate it to a praticle nominated voltage. There is a big serious sweet spot of energy potential between 3500v and 24v. 30 farads doesnt look such a small figure when you have all thatevolatge to tap from.
For those who dont understand the relationship between capacity and volts. High voltage is like compressing the air within a whole room into a small cube and high capacity is like a big room air possibly under a lower pressure. Its best to have both, however you can get better results with higher voltages as you can contain more energy potential in a smaller areas.
Electricity is lighter than gas and IMO there is or more chance of petrol gas exploding releasing its energy in a short burst than a cap has doing this. The efficiency of ICE is lower than that of electric powered. So in essence, pound for punch, fuel gas has the need to store more energy potential than a battery does due to ICE efficiency issues.
All we need to do in this race is cram as much voltage as possible into the lightest smallest area and reap the rewards.
Even a lead acid battery would be a almost a practicle alternative if you could charge each cell from 2v (discharged) to 10 volts (charged).
Metaphoricaly speaking
You could even run a motor off the pressure stored in a O2 tank,
A smaller high pressure O2 tank would offer more of its contents out than a large lower pressure tank. A large tank holds too much unusable energy at the end of decompression and weighs lots more.
Voltage (pressure) is king, capacity (energy storage area) is only relevant to how hard you try put the energy into the said device.
A big battery with no voltage is usless and a little battery with lots of voltage has more meaning.
