317537 said:
No idea what the inductive properties of the cap have to do with anything. Especially since capacitance is basically the opposite/inverse of inductance...not getting into the wireless power thing...
A full cap has capacity and is not inductive and yes quite the opposite.
I made this led torch from 2.5v 2 X 55 farad (5 v 27.5 farad series) caps that charges from a usb slot. If I charge it from 0 volts to +5 volts on a PC psu it will crash two out of three computers in my house from the current it will draw, you can hear the solid state flex inside the psu as soon as you connect them, is that inductance at work?.... Lucky that the leds cut out leaving some charge in the caps so it only happens when the caps have zilch charge.
In electrical circuits, any electric current i produces a magnetic field and hence generates a total magnetic flux Φ acting on the circuit. This magnetic flux, due to Lenz's law tends to act to oppose changes in the flux by generating a voltage (a back EMF) that counters or tends to reduce the rate of change in the current. The ratio of the magnetic flux to the current is called the self-inductance which is usually simply referred to as the inductance of the circuit. The term 'inductance' was coined by Oliver Heaviside in February 1886.[1] It is customary to use the symbol L for inductance, possibly in honour of the physicist Heinrich Lenz.
http://en.wikipedia.org/wiki/Inductance
And I'm betting it will crash the computers. A USB port is only capable of 2A, while a supercap like that (even one with relatively high ESR) will be trying to get like 10A or more out of it.
317537 said:
Im not talking frying Im talking discharging. yeah i agree its a big charge field to take down. You cant or shouldnt shroud a communication antenaa. It would be a lonely world on the radio if you did
Like in the event it gets shorted out? Or just normal use? Shouldn't be any detectable EMF during normal operation. Shorting it out might be a different story. Let's just say I'm betting they'll be using some very expensive, very fast HV fuses in them to cover their butts from lawsuits.
317537 said:
I work at a library. We have books about NASA if that counts.
317537 said:
Lifepos are amazing compared to any other tech out there when it comes to operating temperatures. The only thing is they need a baby mom sitter (BMS) to balance them
A123's have -30°C to 60°C operating temps. I think you said EEStor units work at -20°C to 60°C. Not that much different. :?
317537 said:
Whats that batman? your ass is talking! Can you confirm this?
You're right, Robin!
No, actually, I have no proof they will, but there's not much reason for them not to. Because you don't have to deal with the limited voltage that an electrochemical reaction can produce, you don't need to put a bunch of caps in series. They MIGHT use a bunch of smaller caps in parallel, but that subtracts a little from energy density (since there's more packaging material) and increases the chance of something failing.
On the plus side, multiple small caps could be contained and thereby avert disaster if one of them fails. I'm actually pretty scared of these things. I've had capacitors explode on me for and it's incredibly violent for the amount of energy they store. Vid:
http://www.youtube.com/watch?v=M8nT97CrgcU
Given the energy density differences between a typical EDLC and an EEStor, that would have been about
30,000 times more powerful if it was an ultracap. And the ones in a car would need to be way, way bigger than that tiny little thing. Add to that their multi-kV working voltage and you've got a rather large bomb on your hands if something goes disastrously wrong.
Now, to be fair, capacitors don't normally fail like that. They usually just puff up, get hot, and maybe pop a little. However, the amount of energy they store is small enough to be converted to an amount of heat that might maybe melt the plastic covering on the cap. An EEStor would turn into a red hot puddle of slag if it fails like this instead of exploding. SUPPOSEDLY, they've found a way to take care of the exploding problem. What it is, I don't know, but I really hope they aren't stretching the truth. I'd much prefer it turn into a boiling gob of magma than suddenly convert into an incredibly pressurized cloud of gas...
I'll admit, safety's a pretty good argument for multiple small caps, but the problem is that if the shielding between the caps needed to prevent a cascading failure takes up too much room, the cap won't actually offer any more volumetric energy density than something like LiPo/Co or perhaps even LiFe.
317537 said:
I do like the doubt everyone throws at these companies, like holy dung im still waiting for my freaking Laser TV (its coming) Still with all the doubt in this world, we have those who persist and still invest into these great technologies so we can use them one day.
But, not only have they've actually built and shown off a Laser TV, the plan on selling them sometime before the end of the year. I've been hearing the same "cheese sandwich" analogy out of EEStor for a few years, and those who got into this sort of thing before I did have been hearing it for even longer. :?
I still plan on being one of the first to own an EESU-powered bike if this ever comes to fruition.
317537 said:
Meh. Talk to me after I make more than $10/hr after school.
(I had to try so hard to not reference that "Come back when you're a little...mmm...richer!" clip just there...)
(*previews post* Longpost is loooooong.
