Hi All,
I have watched this post for quite some time, it has been really helpful and has enabled me to interpret the manual better for sure!
I have run into a couple of problems. Mostly of my own doing, which I am hoping someone on here has either experienced or has a better grasp of this than me.
Firstly the hardware.
Controller: Votol EM150SP with Can
Motor: QS 3KW Mid Drive older style without the two flanged mounts
Throttle: SiaEcosys 0-5v
Battery: 72v 20ah on Anderson connections with BMS (used for testing)
When originally setting this up, using the factory settings all was well. The bike was doing all of the things i'd have expected it to do. The only issue I found was that it really wasn't pulling as well as i'd expected.
After reading through these forums I found the settings that I felt was best for my setup and changed them on the controller. !HOWEVER! I did not take a backup of the original settings. I didn't feel it was necessary at the time because the only thing I changed was the busbas current and flux weakening values.
The problem is that when updating the settings it seemed to knock out a bunch of other settings that I had. The throttle voltage settings changed to some randomly low numbers I think they were 0.2 in each area and the hall shift angle moved to 0. I know it wasn't zero but I can't remember now if it was 60 or 120. The specs say 120 but the motor does not sound happy at 120.
I then tried to test the setup with my attached settings (to the best of my memory and having read through the manual to ensure parameters are correct) but the bike will not move forward in low mid or high modes. It will ONLY turn the wheel in 'S' mode. In the other modes you can hear the motor want to start but it just won't.
Please if anyone can provide advice I would very much appreciate it.
Thanks,
