Георгий23 said:Георгий23 said:borko444 said:Are you sure that this $ 3 Chinese scheme where you put it inside the engine is reliable? I do not believe in 10 seconds the engine will raise 110 degrees.
Touching the engine after it stops must be very hot, is that it?
touch it to make sure it is very warm. If it is run over you should not have your hand on the engine
engine is cold
You think I need to turn off the temperature sensor?
First do the test I told you 10 times 100% load on site without driving it and touch the engine cold or very warm this 110 degrees is a lot to touch so
