gonsp
New here
Hi!
I got this cheap motor controller with no specs nor diagram. I haven't been able to turn my motor... This is what I did so far:
Besides motor and battery cables, the controller has 3 other cables:
Things that I have done:
There's a small electronic component separate from the motherboard which basically has a large MOSFET (WSF15P10), which has 6 wires:
I'm trying to understand:
I appreciate any kind of suggestions or guesses!
Thanks a lot!
- 9 pins, called 1T5
- 3 pins. I believe this is the PAS
- 2 pins. I don't know what this is
- I don't have a display, so I have bypassed the ignition so the motor controller is ON
- I have identified the 3 throttle pins and connected them to a 10k ohm potentiometer
- There's a sticker saying: Brakes low level. I have found what I believe is the brake line and it's at 4.5V. So I left it untouched
- I have identified the RX and TX pins for the display communication. I left them untouched
- The ninth wire is brown, and I'm not sure what it is for. More on this later
- Red: High gauge, connected to the battery
- Black: High gauge, connected to ground
- White: High gauge, connected to a pin called DD in the motherboard
- Brown: Low gauge, connected to one of the 9 pins of the 15T cable
- Red low gauge: Goes to the 2 pin cable that I don't know what it is for. It's directly connected to the brown wire too.
- Black low gauge: Goes to the pin cable that I don't know what is is for. It's grounded.
- What this separate component does
- What the brown ninth wire does
- What the 2 pin cable is for
- How can I test my motor
Thanks a lot!
