StephensEngineering
10 µW
- Joined
- Feb 11, 2017
- Messages
- 6
I've got one of the more interesting things on this forum. It's a ride on drink cooler I call the tranzilla. The TranZilla was built in early 2008 and has been through a huge amount amount of repairs and design changes. The base design was made from my old gas powered scooter. The motor was a 300w brushed electric scooter motor, and the cooler is removable and you can insert a boombox that has an AUX input. The boombox also has strobe lights on the outside and on the inside, so the light shines through the logo on the boombox. The cooler was lacking attention and motor strength around 2014, and that’s when I found someone selling some new electronic components.
Earlier in 2014 I acquired some rather expensive PMW motor controllers and dual >500 watt motors with gearboxes for the TranZilla. I also remade most of the chassis to accommodate these huge motors, chopped off extra steel that was from the old chassis, and welded on a wheelie bar. I had a mockup wiring system to test the motors, and with a curb climb from a standstill, was able to calculate 62ft/lbs of torque going into the rear wheels. I’ve had issues getting the PMW controllers working properly.
I upgraded to 36volts so now I three "12" volt SLA Batteries, which actually are more like 14 volts. These are the general batteries you find on eBay.
I've got some sort of issue with the old 24v PWMs after diagnostics (strange issue when I was doing testing on 24v), so I'm currently looking at the Kelly KDS36200e or KDS48200e. I have 3 "12"v 22Ah SLA batteries. Problem is, they have an extra cell in them so they really supply 14.5v each at full charge. Would it be safe to get the 36 volt controller? Or do I need the 48 volt controller?
Also, how do I charge these batteries now? My system actually puts out 40-45 volts so a standard 36v scooter charger may not work.
