Alan B said:It sounds like the new motor is a lower voltage motor, so it will spin faster and draw more current. This may make the controller slightly hotter. Much hotter indicates a phasing problem.
ClintBX said:Alan B said:It sounds like the new motor is a lower voltage motor, so it will spin faster and draw more current. This may make the controller slightly hotter. Much hotter indicates a phasing problem.
Lower voltage? The only specs I see for both controllers and motors are their watts and the amp discharge.
And I'm pretty sure that my pairing a 1200 watt motor with a 500-600 watt controller is the source of the problem.
That said, I still haven't played around with the phase order yet. The plastic of the controller's yellow phase has sortta fused itself. I don't really want to mess with it until I have the new controller. I figured I'll test out the phase order then. Still skeptical that the phases are wrong. Its just too smooth.
ClintBX said:And I'm pretty sure that my pairing a 1200 watt motor with a 500-600 watt controller is the source of the problem
This means that connection point has gotten very hot, which usually means it is a poor connection. It can also mean it is arcing inside the connection, which can also cause controller heating due to RF from the arcing feeding back into the FETs and disrupting their normal operation. (can also blow them up).The plastic of the controller's yellow phase has sortta fused itself.
ClintBX said:Another thing I didn't mention is that my battery connectors have been melting down a lot since the new motor.
amberwolf said:This means that connection point has gotten very hot, which usually means it is a poor connection. It can also mean it is arcing inside the connection, which can also cause controller heating due to RF from the arcing feeding back into the FETs and disrupting their normal operation. (can also blow them up).
What are the actual measured voltages under load, and what are the actual currents drawn from the battery, and what are the actual wattages?ClintBX said:Okay, just to be clear, I'm running a 48v 30 ah battery with a 1200 watt motor and a 30 amp 500-600 watt controller.
amberwolf said:What are the actual measured voltages under load, and what are the actual currents drawn from the battery, and what are the actual wattages?ClintBX said:Okay, just to be clear, I'm running a 48v 30 ah battery with a 1200 watt motor and a 30 amp 500-600 watt controller.
If you don't know those things, then you should test them, because troubleshooting based on "specifications" that someone decided to print on a part or a web page is not reliable--everything anyone can say to you is a guess, at best.
If you don't answer/don't test things people suggest, all they can do is make more guesses, speculate more in random directions, wasting more time for everyone. Sometimes it turns out to be a waste of time to do the tests, too, but if they're not done there's no way to know what the problem is, or what to do to fix it, without just swapping stuff out till it goes away.
That gets expensive and frustrating.
ClintBX said:Hi EPFMs,
I just received a new hub motor for m ebike and after connecting it and taking it out on m commute today, I noticed that my controller is getting pretty hot.
The new hub motor is a 1200 watt.
The controller is a 36/48v 30A.
I don't know an other specs for the controller like how many fets but I know that when I got it, the ad said it was rated for 500/600 watts.
The controller gets piping hot. I have it in a black seat post bag. Its one of those rosswheel bags. It even smells hot.
Is this happening because of the obvious? Do I need to upgrade to a controller that is rated for a 1200 watt? Or is it something else?
Clinton
All the watt meters I've used will retain a trip statistic for at least:ClintBX said:How am I supposed to test under load? I have a watt meter <snip> but while I can use it to tell my ah usage after a ride, I can't look at the numbers while riding.
Without the load end connected, then the only function it can do is voltmeter--it can tell you what the volts are right now, and it can tell you what the lowest volts (sag) were during the ride.(can't currently connect the load end due to yet anotger bad connector)
If you want to mount it on the bars to read realtime, then you'd need to run thick-gauge power wires from the battery, to the bars at the wattmeter, then back down to the controller.Would I need some longer wires?
A wattmeter (which you already have), or a multimeter, or separate voltmeter and ammeter.I don't know what equipment to get,
Alan B said:If the top speed is the same or similar then the winding is not much different. What were the before/after top speeds? I see there was some mention of 10 km/h, but no reference as to from what speed to what speed. That's a pretty small change in top speed, not likely enough to explain the tremendous delta T in controller temps.
If the performance is significantly different then yes, that could be a major factor. The OP has not made clear how much difference there is. The controller temperature difference (as described) between the motors is so huge it would likely require more than a 2x motor difference.
It would be nice if the OP told us more about the speed / acceleration differences between these two motors. The nameplate values aren't very helpful.
In any case the data we have points more to incorrect timing than to the motor change. Going from what is probably a 6 FET controller to what is likely a 12 FET controller will help, but not solve the problem if the phasing is incorrect. Of course the new controller will need to be rephased anyway.
Never say never.We can fairly accurately predict watts by speed for a typical bike. (flat, no wind) 350-450w gets you 20 mph, takes 1000w to go 30 mph, and 25 mph is never less than 600w.
