Alan B said:But many folks run small 6 FET controllers with DD hubmotors without this level of heating.
Are they running 1200 watt motors on 6 FET?
Voltron said:Sure it's allowed... And low amps, like less than 5. Not 15 or 20.
And the new controller won't reduce your mileage... as long as you don't go punching it every block. But that is tougher than it sounds with a nice new more powerful controller
Alan B said:Good start.
Unloaded max speed and battery current for both motors is what now?
Is this with the 6 FET controller? What is the status of the 12 FET controller?
Let's get all the data in one posting instead of dribbling it out.
Alan B said:If there's no integrated speedometer on this bike then measuring wheel RPM and computing speed would work. Knowing motor speed and voltage we can compute Kv for each motor and try to match to the sim.
Alan B said:What are the weights of the two motors? Are they both "9C" clones (similar diameter, width and weight)?
ClintBX said:and it supposedly has 520 max RPM.
Alan B said:What voltage does the 520 RPM correspond to?
d8veh said:The photo is too bad to get anything meaningful from it. If thr throttle is a 5 wire one, it's normally because it has LEDs and a switch. Two wires are independent for the switch. One wire carries battery voltage to the LEDs and the remaining three are for the throttle. Maybe yours is different. You didn't show the throttle itself.
When you mix and match controllers with motors, the connection sequence is often not colour to colour, so you have to find the correct sequence by experimentation. There's 36 combinations of which three should work correctly.ClintBX said:Hey guys, I need your help.
I finally got my hand on some decent bullet connectors. I'm in the process of instaling the new controller and after doing all the hall connectors, the phases and the throttle, when I twist the throttle, I get like 1 mm of wheel movement followed by a click sound and then nothing.
What is that? Is it a hall sensor issue? I need to be back on the road ASAP. please help.
amberwolf said:Did you do the testing to find the correct phase/hall wiring combination for your new controller vs the existing motor?
If not, you have to do that first. There is an article in the Wiki and numerous threads on the forum about how to find the right hall / phase wiring combination (combo), if you have not done this before.
If the controller has a learn function you can try that first, otherwise you must manually find the right combination.
