zro-1
Xiongda has a relatively new hub motor available that's even smaller and much lighter than the Q100 but has a higher gear reduction which should provide greater torque at the same power levels. I didn't find any threads here discussing this motor, so I figured I'd start one. I think this motor should be very interesting to people on here who are building light, stealthy, lower-powered ebikes that focus on assist rather than raw power—or the folks in the EU who have low power restrictions for road bikes.
To get started, here are the basic specs for the rear motor (plus what I've learned in chats while ordering one):
Voltage: 24/36/48V
Design: Brushless
Wattage: 201 - 300W
Rated Power: 250W
Color: Silver/Black
Weight: 1.4kg (3.09 lbs)
Gear Ratio: 17.5 (for 26", 29", 700c, etc size wheels), 12.25 (for 20" wheels), and 8.4 (for 12", 14", 16" wheels)
Wheel RPM (at 36V, 17.5 gearing): 210±10 RPM
RPM range: 210 - 320 RPM depending on gearing (they suggest no more than 28 kph (17.4 mph) speed, but that may be for legal reasons)
Maximum Torque: 40N.m
Axle width: 135MM (can special order 120mm as I've done)
Brake: Disc-brake/V-brake
Freewheel: 6~7s Freewheel (single-speed in 120mm)
Cassette: No, freewheel only
Spoke holes: 36 (32 holes is not available at this time, but they are considering it)
Pole pairs: 8
Effective pole pairs: 17.5:1 = 140, 12.25:1 = 98, 8.4:1 = 67
Approximate kV: 5.83 RPM/V
Sensors: Optional (hall and speed sensors are available at no extra cost)
Pricing: (not including shipping)
When you order the motor they will ask you for the desired voltage and wheel diameter. I suspect the voltage is for the controller, and the wheel diameter is for the gearing. Bonnie, the sales rep encouraged me to get their controller with the motor, which I declined. Xiongda will not cover a warranty on this motor if it's not used with their controller. I ordered the motor alone without a controller since I'm using a Phaserunner, and had to let them know that I understood that there wouldn't be warranty coverage if there was a fault. In other words, if you hotrod this motor, and burn it out, they won't cover the damage, which is to be expected of any company.
Here's the dimensional diagrams for the front and rear versions of this motor:
Note the cable exit inside of the forks instead of out the end of the axle. That should be a nice change for those of you using Q100s. Also, the Q100 has a total diameter of 120mm where this motor has a total diameter of just 101mm.
And here are some images of the motor:
I'm pretty excited about this motor, and I'll be adding info here once I have my order in hand and can examine it in depth and test it out. I'll also provide some side-by-side comparisons between this and the Q100. I may try to take the side cover off to get a look at the gears, and I'll share the Rs and Ls of the motor once I get it hooked up to the Phaserunner and run it through autotune.
Voltage: 24/36/48V
Design: Brushless
Wattage: 201 - 300W
Rated Power: 250W
Color: Silver/Black
Pole pairs: 8
- YTW-06: $75 USD
- Sensorless Controller: $25 USD
- Sensor Controller: $25 USD
- Display: $25 USD
- Pedal Sensor: $3 USD
- Throttle: $5 USD
- Brake Levers: $5 USD
