I ended up taping most of the plug, just leaving the most rounded corners:
That way I can test if the rest loosens but not the corners, then I know that just release film wont work.
But hopefully the damage wont be that bad, so the mold should still be useful
That is the plan anyway..
Here it is, one layer gelcoat. I didnt want to wait to tomorrow to lay another one..
I waited an hour before starting with the fiberglass, and it seems to have worked out.
It was rather warm, maybe 25 degrees C and 1,5-2% hardener.
I dont think I have even test ridden the bike with the fardriver, so now seemed like a good time to do so.
And I started playing a little with the settings:
There are some confusing things:
Rated speed, I havent tried changing it and I dont know if it is the default setting or a learnt setting after self learn.
The manual seems to list it as a learnt setting, but shouldnt it be about double of what it is?
I dont know what the LD, LQ, FAIF or phase offset does, or if I am supposed to change anything there.
Rotation limit ratio, this I thought had to do with field weakening.. maybe. Haven't tried changing anything yet.
It seems to be used for rpm limit in high. Low and mid has an rpm limit.
I havnt messed with the ki/kp settings, those seems to be default for "high power motor" or something like that in the manual.
I changed AN from 0 to 16, that seemed to be default for IPM according to the manual. Unclear what it does..
LM seems to have something to do with current build up, 22 is default. Havent tried changing it. I suppose it is influenced by the ki/kp values.
The other four is interesting, MOE ? I dont think I saw that on the computer. Same thing with weak response and release throttle.
I tried changing release throttle (0-7) not sure if there was a difference.
Throttle rate, it was 128 first. I tested it and didnt like it. I always got wheel spin and no wheelies. I raised it up, and it got a lot better
I didnt feel like there was a throttle delay, but it still resulted in that I gave to much throttle before I changed. Now it feels very responsive
I think 224 is max, so I guess I might as well change to that.
ECO coeff, I thought at first that it was some throttle tamer and set it to 0 or 1 or whatever. But it was the other way around, it got sluggish then. So back to 8 (max). Havent tried the other settings.
A few more settings, Follow is interesting.
It seems I can only get regen on a button or throttle release.
The throttle release seems buggy, sometimes I get a delay when I get back on throttle after throttle release.
So that seems pretty much unusable as it is, and that is something I really want
I guess the best way is to use a domino throttle and use the switch for brake regen, that seems to work better. Even if there seems to be a little delay before it kicks in sometimes.
PC 13 is boost I think, seems pretty much useless. It can do the same thing as the brake, and some sort of cruise control.
There is also a wire for cruise, I wonder what that is good for then :?
I dont think I can do anything with the calibration, I dont think I have tried though..
