If i understand you correctly, than i think you could be right. I think it has something to do with the regenerative braking system,LEVer said:Looks like "voltage sag" to me.
Ahh ok, i see. Well i still ordered The Benchwheel board, so lets see if i'm going to run into these connection issues.LEVer said:Hmm...voltage sag does not have anything to do with regenerative braking. I think the board is cutting off because the battery cannot feed the motors anymore, and either the ESC or the BMS in the battery pack is shutting it down to protect it. That's why when you turn it off and turn it back on again, the memory is reset and the board becomes operational again.
It also does not matter whether you go forward or reverse, it will not activate the regenerative braking. Regen happens when the motor is not being powered from an internal source, but an external one, like gravity....or like a hamster inside a spinning wheel next to the board's wheel.
Thanks for all the info, the english manual will come in handy for me. Could you explain how you hooked up the LED lighting too? That looks awesome.shanghailoz said:Haven't had problems connecting mine up (other than the first initial sync, but that was more a case of me not being able to read the chinese manual too well).
I wrote up an english manual with clearer instructions (see earlier in the post).
If it does get low on power, it the skateboard turns off.
The battery light will start flashing.
You can power it off and power on again and get about a km or so more, but then you're draining the battery too much (lithium is happiest lifetime wise in the 15-85% charge range).
Mine was repaired under warranty. Sent it in, got it back a week later (I live in China though, and its cheap to ship to Hangzhou where their factory is).
Justin said:I got a nice deal on it, so i can always
use it pull off parts and start a DIY Boosted clone
psychotiller said:erwincoumans said:That is only a single mount for USD$ 100, so we would need two, at $200... Then the wheels and truck for say $50, and 2 motors at $50 each, and you are already at $350. Then you need 2 pulleys, 2 hub drive adapter, 2 timing belts and motor covers and easily reach $400 to match the Benchwheel.psychotiller said:Problem solved! No welding, $100, In stock. http://www.ebay.com/itm/171821983261?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
+115 shipping? That's $415 for the benchwheel...And you'd get who know's what with those motors. 2 tacon bigfoots would cost you $110 and they're solid!, Rear pulleys, front pulleys and belts would cost you $60.
I ordered from Banggood (a chinese site, that ships worldwide for free). At the time of ordering the board was €480,- and i ordered via their mobile appLeonard said:Justin said:I got a nice deal on it, so i can always
Could you give us info about that nice deal?
What did you break?cwah said:any idea where to buy parts for benchwheel?
jmack549 said:Did we ever get a top speed confirmation on this? I ordered a dual which should be here Thursday, I should be able to get a number this weekend.
