toro1978 said:
This is a while after I got the bike - on this pic it already has the wheels relaced with other hubs and brakes to prepare it for the motor installation. It also has an air suspension fork (mocked up to look like a double crown fork).
Very cool looking bike Toro, it's got a real Steve McQueen Great Escape look going to it. It looks really comfortable too. Thanks for posting.
Recently found an old Kona Blast Deluxe on my local CL, so I swapped my kit from the Trek 4300 over to it. Now I have front suspension and hydraulic disc brakes! The Trek 4300 originally came with a suspension fork, but I snapped it when I originally installed a 48v 1000w FHM on it without torque arms. I didn't know the importance of them at the time! I ultimately replaced it with a rigid fork, and installed a 48v 1000w RHM instead. This setup never really gave me any issues, but I always wanted disc brakes and got the Kona at a reasonable price.
Hello,
Here is my Specialized Sirrus « electro-gravelized ».
BBSHD, 52V (Samsung 30Q), no throttle.
Shimano road shifters, MTB rear derailleur with a 11-46 cassette, 52T front.
11-46 is good for almost everything, from slow speed with 3 kids (one behind me on the bike and two in a trailer!) to fast commuting (around 38mph max).
This machine is extremely efficient and a joy to ride.
Before :
Full size: https://www.casimages.com/i/19022210525224684416131161.jpg.htm
After :
Full size: https://www.casimages.com/i/19022210525224684416131158.jpg.html
GIANT MTB ( UNKNOWN MODEL BOUGHT 5TH HAND BUT VERY ROBUST FRAME )
1ST VERSION - 72V 20AH SABVOTON 07260
2ND VERSION - 72V 35AH WITH 3D PRINTED BATTERY & CONTROLLER HOLDER
VERY STABLE DESIGN FAST BIKE. Only Con so far weak breaks they need disk upgrade.
OK, here are my two cents: about two years ago I made the bamboo/carbon bike using a cheap bike as a donor. Overall, I liked the performance of the new frame, but it didn't help to fix a major problem in our area - steep hills :) So, the usage of the bike was more for recreational rather than for commuting purposes. Recently, I've added a simple front hub motor (250W, 36v) and this made a big difference - I can get almost everywhere I need using the bike and I lose not more than 5-10 min for an hour of commuting w.r.t. public transportation or a car. If the assistant is used in an economic mode, the 36v x 8.8 Ah battery lasts for about 50km. If I'm in a rush to get to work then it's closer to 25-30km.
And here's another creation based on the same hub motor, respoked to 700 wheel. The original bike (I used a stock image since I didn't take one before the conversion) was elegant, but too heavy for my wife to climb the hills (see the previous message).
Fatbike frame 200mm rear axel
locked out front suspension
72v50a gekoo controller
10inch 50H motor
26x2.35 front 130/90-10 rear
18S 20Ah battery
New to ebikes and to the forum...
Really cool creations I have seen so far.
I just wanted to add my less than spectacular "simple" conversions..
I used a 2Ah 60v battery from a snapper leaf trimmer. I did this so I could easily swap out different capacity batteries (since I also have 4Ah batteries that came with my snapper electric lawn mower)
The "battery dock v0.1" was designed in Maya and 3D printed in ABS plastic (better battery dock in the works :) )
1000w hub motor (easily pulls 1500w). 27A controller paired with a kt-lcd3
Was Just a $5 bike from the Scrap yard first picture is the closest I have to a before.. Now have two of them :) check the youtube link [youtube]https://youtu.be/AM1MPMpCVRg[/youtube]
Here is my second built. I replaced the BBS01 on my Surly Krampus by a G310 motor kit provided by Grin.
Battery 52V/10.5+7Ah, rims Ryde Andra 40, tires Surly Extraterrestrial.
Before :
After :
Milan GT velomobile (CwA value = 0.0368)
Before:
Two chain wheels, 9-speed derailleur, SRAM Dual Drive = 54 gears
After:
Patterson Metropolis 2-speed drive with shortened cranks, 9-speed derailleur, new lighting system, new wheels, water-cooled drum brakes, rear disk brake, new rear shocks, elastomere suspension, modified steering geometry, various other updates, Bafang SWXH, Phaserunner, 20s battery, consumption around 6Wh/km at 60km/h, 350km battery range, 75km/h top speed
https://etrike.wordpress.com/tag/milan-gt
Still fast enough to smoke some roadies in a peloton, with an empty battery. ;)
Hehe!
Since the view would by slightly restricted...
...and the Spandau's degrade the aero propertys, I think an extendable mini-gun turret in the back would be preferable.
It would also cover my six quite nicely. :D
Jil said:
6Wh/km @ 60 kph !! Cx is everything...
On open roads without frequent traffic lights, I think its closer to 5.8 or 5.9Wh/km and it currently got a relatively slowish tire at the rear wheel (Big Ben 50-559). I have to do some further testing, but with some light pedaling (75W), 3.3Wh/km @ 40km/h, 4.5Wh/km @ 50km/h and 6Wh/km @ 60km/h isn't far from the truth. If the road goes ever so slightly downhill, it gets even more ridiculous.
Jil said:
What is its weight ?
About 38.5kg without battery, but with hood. I can fit three, used, 20s battery packs behind the seat, that together have roughly 2kWh capacity left and weight 5kg each. With tool bag, big Abus U-Lock, water bottles, two Radical velomobile bags with some stuff, it should weight close to 60kg. With one battery and about 120km battery range, close to 50kg.
Its an old, glass fiber, Mk2 version that should have weighted about 32.5kg (I forgot to put it on a scale before tearing it apart). The current, carbon fiber, Mk4 version weights 25kg.
