That would have to be a DC-DC converter with current limiting.
FWIW, it's going to use up some of your charger power in the conversion, anything from 10% to 50% depending on how efficient it is at any particular conversion and how extreme the conversion being done is, so charging your battery will be slower with it, and it is one more point of possible failure to either prevent charging or to cause other problems, and it's one more source of waste heat.
But...it would help people turn regular non-current-limiting (or crowbar-type) power supplies into proper chargers, assuming it does actually work correctly.
The linked page does have a potentially useful connector chart, which is attached in the page copy below, in case of link rot:
Zoom
(19)
CHARGER ENHANCER CE140
Sale price$69.00
Charger Enhancer (CE140) – a compact, standalone device designed to elevate your standard charger.
It offers effortless monitoring of charging information, customized charging limits for long battery life and storage, and enhanced safety features including auto-disconnection to prevent overcharging and protect against charger failure.
To set up the charger enhancer properly, you'll need a pair of adapters to connect your charger and your device. We provide a free pair of adapters, please select the one fit for your charger. Not sure which one to select? Read our Selection Guide.
Select The Included Adapter:GX12-2
GX12-2
Sold out
Extra Adapters
GX-XT60 Adapters (A Pair) For CESale priceFrom $9.90
+ Add
+$9 for air shipping.
Our typical shipping time is 7-10 business days.
Share
CHARGE SAFE WITH AUTO-DISCONNECTION
OPTIMIZING BATTERY MANAGEMENT
ENHANCED INFORMATION
Charger Enhancer provides crucial charging information, including voltage, current, power, time, and energy capacity.
As we become familiar with CE140, we can check electric grid stability before connecting our vehicle to a charger in new locations, inspect the charger's status after an electric shortage or verify its output after charger adjustments as a precautionary measure.
We can measure the battery's effective capacity for future reference, assessing its natural decay over time or to determine when a battery replacement is necessary, helping mitigate risks when considering the purchase of preowned vehicles, or verify the battery's integrity after an impact or when observing a sudden decrease in mileage.
SAFEGUARDING PEACE OF MIND
ENHANCED SAFETY
With Charger Enhancer, constant supervision becomes unnecessary.
Regardless of your charger, CE140 proactively disconnects the power supply upon reaching a full charge or your preset partial charging level, preventing overcharging and saving energy.
Even in the event of charger failure, improper settings, or unexpected occurrences with the electric grid, CE140 acts as a one-time insurance, adding automated protection layers for your vehicle's health and your peace of mind.
DC 30-140V
UNPARALLELED COMPATIBILITY
MASTERING BATTERY HEALTH
ENHANCED CONTROL
Charger Enhancer, has been designed to provide sophisticated yet user-friendly solutions, to get the several benefits of taking control of the charging process.
With CE140, you can customize the charging level and overcurrent protection limit according to your specific needs. Among other benefits, controlling the charging level with CE140 makes it easy to achieve battery levels for healthy long-term storage, facilitates the equalization of battery packs before replacement, and by partially charging while periodically balancing cells to prolong the lifespan of expensive lithium batteries.
CE140 features inbuilt automated, customizable, and quick-button functions, empowering you to take control, extend battery life, increase safety and reduce your environmental footprint.
A MIGHTY POCKET COMPANION
ENHANCED COVENIENCE
Charger Enhancer seamlessly combines power and portability, featuring an impressive capacity able to support up to 30A of current and a continuous charging power of 4200W. CE140 effortlessly handles the high demands of most PEV 'fast chargers'.
Despite its remarkable capabilities, we've managed to encapsulate this powerhouse in a size that fits in the palm of your hand. CE140 can effortlessly slip into your backpack, be attached to your charger, or placed in any location of your choice. CE140 does not require complex integration with other devices nor internet access.
PIDZOOM CHARGER ENHANCER UNBOXING
Play video
SELECTING ADAPTERS
- Why Use Adapters with Charger Enhancer/Fast Charger?
Each vehicle possesses distinct characteristics, necessitating adjustments. By utilizing suitable adapters, the Charger Enhancer/Fast Charger can seamlessly connect to the charging ports of various devices.
- How Do I Choose the Right Adapter?
Identifying the suitable adapter involves recognizing the type of charger port in use. Typically, the charger itself displays a label illustrating the layout of its port. Once you ascertain your charger's port type, refer to the diagram below, displaying our adapter layouts, to select the appropriate one.
- What's the Maximum Charging Current Supported by the Adapters?
The maximum charging current supported varies across adapters. Detailed specifications for each adapter are provided in the diagram below for your reference.
ADAPTERS LAYOUT
COMPARE & PICK
Charger Enhancer CE140Sale priceFrom $69.00
View
Charger Enhancer CE200Sale priceFrom $79.00Regular price$99.00
View
Voltage
DC 30-140V
DC 10-200V
Current
DC 0-30A
DC 0-20A
Dimensions
95x72x26 mm
(3.7×2.8×1 inches)
95x72x26 mm
(3.7×2.8×1 inches)
View all
FAQ
Q1. Is it like a WIFI switch or a monitor?
Q2. Isn't CE140 overlapping with BMS purpose?
Q3. Do I need the additional protection features of CE140?
Q4. Is CE limited only to "old" vehicles or basic chargers?
Q5. Isn’t "partial charging" dangerous for batteries?
Q6. Is there a specific sequence for connecting the wires?
USER MANUAL
Charger Enhancer CE140 User Manual
(also attached this to the post)
