GGoodrum
snowranger said:GGoodrum said:Hyena said:Fair enough.
Any chance of posting a circuit diagram and component list for those of us who want to play around with different numbers of cells?
Fell free to tell me to nick off if this is infringing on the time / effort you put into testing and making these boards![]()
The circuit couldn't be simpler. It is just 2-1/2 parts per channel. Here's the schematic:
This example includes the active cutoff section, which should be good for well over 100A, but I prefer to use the controller's ebrake input. It is more reliable and works with virtually any ebike controller.
Does this work with the RC ESC or throttle interfaces or servo tester?
Yes, it works with either a servo tester or with Fechter's throttle board, which has a dedicated set of pads for this function. For use with a throttle tester, you simply connect the LVC ground, to the ground on the tester, and connect the LVC "+" lead to the center lead from the potentiometer or the signal lead from a a hall sensor-based throttle.
-- Gary
