Zippy Flightmax / Turnigy lipo testing
Status
Not open for further replies.
No worries mate, happy to help :)
Hobbycity also sells cheap sheets of double sided tape - grab a few sheets with your order of lipos. It doesn't weigh much so it's good to fill up the rest of your order if you have 100g or 2 left before you go into the next shipping weight bracket. Now's the time to buy, our formerly miserable Aussie dollar is now back up to 90c US. When I bought my last lot of lipos the exchange rate was only 78c, up from 62c when the arse fell out of the stock exchange :?
Ain't it great!!! they were talking 3-4 years when it crashed before it would again rise to that level the dive
had to happen as i was ready to buy my first batteries for my first e-bike too didn't it :: sigh :; LOVING
the new exchange rate! Rough figures i will be able to fit around 24 44v 5000mah packs with easy
As discussed starting with the 4 packs to get the bike mobile and adding to that each fortnight until
i have my goal of 20ah 44v pack should give me some decent range i hope if not another 8 packs will be
loaded up the extra wide bottom brackets needed for 4in wide rimz/tires allows me alot more width on
my enclosure than i really need with these nice small lipos packs ;)
KiM
dang.... that didn't take long! add me to the dreaded list.. :shock: :( :oops: :cry:
my supposedly dummy-proof design... tonight i'll be taping the charge leads and charge balancers together. :!:
what happened: i finished charging. unplugged charge lead (but left paralleling balance lead in!), and plugged in the serial dishcharge cable. or tried to. as soon as the powerpole plugs made contact, the light, fire, flame and fusing of the powerpole contacts... mainly in the middle of the plug.
(funny, methods, huh? since i was just asking when 2A travel the balance wires...)
shock, smoke, fear. but crisis over? pulled everything apart and checked each individual pack, voltages all okay, still sitting at 4.17.
phew.
one pin on my db25 must be off. when i plug one any jst-xh connector into it, the attached lipo buzzer goes off. w/ separate mks-propo balancer, they all look fine.
powerpoles are a mess though. not salvageable. alligator clips to serialize the leads to get home?
ah, this is a fun hobby.... :wink:
<methods gets a smug look on his face...>
Allow me to take this excellent opportunity to point out once again what I always preach from my well worn soapbox :D
1) The most common mistake is the leave the balance taps configured in (Series/Parallel) then try to plug the main power lines together in (Parallel/Series) causing vaporization of the main power connectors
(if you are lucky)
The best solution to this is to charge in the exact same configuration that you discharge in.
Set it and forget it.
48V supplies and DIY BMS circuits are getting way too cheap for any of us to need to transform the packs for charging.
Build a 6S or 12S or 18S or 24S version of Gary's Charge Balancer and use some number of power supplies strung in series for charing
It is usually Ok to tie a 24V supply in series with a 12V in series with a 36V (etc) to get some large voltage like 72V
-methods
I've done away with charging mistakes by using andersons in the above configured method and not charging on the bike. The bike has an 8 pin series discharge lead hanging off it and the charger has an 8 pin parallel plug. Using the d sub plug is supposed to stop the problems of getting your balance taps mixed up, but only if you remove the discharge lead first! (which is now impossible to stuff up for me because I remove the batteries from the bike to charge)
What Methods says is right though, if I was starting over I'd hunt around for a suitable power supply, or better still pay a few bucks extra and get one of the neat metal case bmsbattery chargers ($53 for a 400w charger set to what ever voltage you need)
The problem arises when you include the balance taps in with the swapping. Ideally you want to always parallel packs at the cell level, both for charging and for discharging. That way each group of paralleled cells act like one big cell because as soon as they are connected, the voltages will equalize to the same level. Stronger cells will "help" the weaker ones and slight variances tend to average out. They will stay balanced better this way as well.
If you must use an integrated RC charger/balancer, like the 1010B, you really need to use a connection system that puts all the balance taps in the same connector as the main power leads. That way, when you swap connectors around, to turn a 20s2p setup into a single 10s4p configuration for charging, there's no chance of screwing up by leaving the balance plugs connected one way, and the main pack leads the other.
A still better solution, in my opinion, is to simply leave the packs in the discharge configuration all the time and then use an external supply, or supplies, to charge the whole pack. With a 1010B set for 10s, it can only manage about 5A of charge current so to do a 10s4p pack it will take over four hours to fully recharge the whole setup. With a hundred dollars worth of external supplies, you could cut that time down by at least 2/3.
I purposely did the balancers so that they are self-contained and completely independent from the charger/supply setup. Each balancer plugs into a single balancer pigtail coming from the LVC/parallel adapter board. There's no order they have to be in and it doesn't matter if you leave the main pack leads connected in series, or re-connect them in parallel, as long as you have a balancer for each 6s (or 5s...) block. Here's an illustration of what I mean:
This arrangement lets you discharge the four 6s2p groups all in series, in a 24s2p 88V/10Ah configuration, but charge it as a 12s4p 44V/20Ah arrangement. This is done with a simple set of four Andersons. The trick is you need four balancers, if you are going to balance them at the same time as when you charge the packs. If the packs are reasonably well balanced, you could charge them all at once, as shown, but then hook the balancer(s) up after they've been charged. In this case, the LEDs will all lit up green and the shunts will be fully on. They will drain off to where the shunt cuts off and the LED turns red. At that point every cell will be at about 4.11V. That way you could actually get away with using a single balancer, but it will take awhile to do all four 6s2p groups.
The point is is you don't need to worry about paralleling the balance plug leads for charging/balancing, like you do with trying to use a single RC charger to charge a 20s or 24s pack setup as 10s or 12s.
I finally got my four MeanWell S-350-24 CC/CV supplies. I will test one in a bit, to see what the voltage adjustment range is for this model.
-- Gary
regarding my recent setback, and perhaps to echo the point above, i'd left the db25 charge connector in, and saw ungodly light when i touched the anderson plugs together. (no KFF though! knock, knock). the battery side db25 seems to have survived, but in case anyone is curious, here's what happened to the db25 balance side which stayed connected:
after civil war surgery last night on the power leads, with assorted used andersons, i was able to get back on the bike for this morning's commute.
i'm charging the whole pack straight, no balancing using the parallel harness. two packs are lower than the others, but i will alligator clip the leads on each 10Ah pack and monitor them with the chargery lipo buzzers.
in case you were curious... ;)
I just fired up one of the MeanWell S-350-24 supplies and checked the voltage adjustment range. It goes from a low of 18.47V to a high of 27.43V. I set it to 24.9V, which is 4.15V per cell for a 6s pack. It will definitely work for 5s packs. For the same 4.15V per cell, it would be set to 20.75V for a 5s pack.
-- Gary
Not do to Gary out of business at all, but if you're on a budget I reckon you could get away with one balancer and just connecting it periodically. As I said previously I haven't balanced in over 100 charges and I think methods is in the same boat. These turnigys seem to be very well behaved - if you don't get a dud from the get go!
That said, whats the latest on the balancers Gary ? Still testing or waiting for stock of the boards ?
I second that.
Not everybody can afford 2 or 4 of Gary's balance boards but EVERYBODY and afford 1.
A trick is to just charge your pack up to a volt or two under HVC.
Set it to # cells * 4.10V
Very rarely will you have a cell get above 4.2V (if your pack is healthy)
You can then walk up and poke the single balancer into each group of 6 to bring down any high cells.
After you see how awesome gary's balancers are then you can buy 2 more, crank your charge voltage up a little, and have it be plug and play!
Really - Gary has a winner here. Modular LVC and Balancer boards that are independent. This is what you want to spend your money on. Methods seal of approval :D
-methods
Thanks for the good words, but I totally agree that most won't need to balance packs with every charge, especially with fairly new packs. As the cells/packs age, they tend to drift apart a bit more, so more frequent balancing might be needed then, but if packs are treated well, that should take awhile.
I'm waiting on parts, which should show up tomorrow, and I'm working on instructions, but I have the boards now.
-- Gary
Great news GGoodrum, I just want to say that you are making a great job and with the seal of approval from Methods this must be almost bulletproof. :D
Methods seal of approval is often marked with a charred black fingerprint :mrgreen:
-methods
GGoodrum said:
(I just bought six Turnigy 6s-5000 20C packs for $60 each...), t
Where did you find such a deal? I'm interested in building some LiPo packs...objective of making multiple 4s 10000mAh members.
Thanks.
hi
I got my first batch of turnigys today. 12 packs of 5Ah 5s, I also got a 1010b+ for charging with the A30 psu just in case I need a second charger(and I probably will) I am waiting for LVC boards from gary to arrive I should have the packs balanced by then. I did get a cell log 8 to keep an eye on the individual cell voltages.
methods you advised to run a bead of cyano along the balance connector at the wire end to stop the wires coming out and use some cyano activator, you said NOT thin i foung thick will that be ok.
I have reset the cut off point of the icharger to 4.15v to match with the way the thread is going.
for the moment I am going to have to be one of these people that charges one way and discharges another it will be charging as a 10s 6p pack and discharging as a 20s 3p pack, when time and money dictate I will change the system but for the momentthis is the way I have to use, to save from making the same mistake i have seen so many times on this thread can someone please say which order to change the connectors round in, using the names power connectors and balance connectors.
Geoff
What, you didn't read all 26 pages of this thread ?! haha
www.hobbycity.com
The order doesn't really matter, as long as both the power and balance connectors are disconnected from one configuration before you start to connect them in another. Maybe tape/shrink wrap your charging and discharging harnesses (balance and power wires) together to avoid confusion.
I guess to be on the safe side you could make it a rule of thumb to remove the balance connectors first. The power connectors can be connected in series or parallel happily but if the balance connectors are still all in parallel then the sparks commeth.
geoff57 said:
... it will be charging as a 10s 6p ...
Geoff
6P = 30Ah . . .
10S = 37V
It is going to take one hell of a long time to charge that at 350W - that will be about 9A charge current.
I would expect at least 4 hours.
The balance phase will be painstakingly long... Maybe another 4 hours since 350mA max is only 1%
You will need to modify a few settings in the charger including the 2 hours auto-shutdown and the capacity protection.
If I were you I would probably take large resistors and manually balance the cells before you charge. One sneaky trick is to use the chargers "Discharge" function on individual cells.
Say you are at:
4.12
4.13
4.11
4.12
4.19
You could tap the two balance leads for the 4.19V cell, set the discharge current to two amps and the discharge voltage to 4.12V. This would be very fast.
Never tried it (as I just use big resistors and my fingers :twisted: ) but it would work.
-methods
Methods,
I thought that was the two thumbs up that came with KFF?
Gary,
Nice work on these man, as already stated I am very keen on picking up some of your new HVC/LVC boards to regulate the charging... will the new balancer boards be available in kit form any time soon? If so I will just order everything at once so I can do a review and how to on connections.
I have a new 15S 15AH pack (just got it today) which I am breaking in currently but I will eventually be using this pack as 10S 20AH - do you see any problems with the transition so long as I have sufficient channels to handle the 15S total maximum pack size for now... I should be able to scale that to 10S4P for 20AH when needed for RC drive?
Regards,
Mike
PS: I much prefer the newer turnigy lipo cells... just the connectors alone are a blessing - no more male to male series jumpers = )_ The BM6 coming from Hobby King are still the v2 again (haven't gotten a V3 from them for about 2 months now), the packs aren't super well shrink wrapped or insulated so I would strongly suggest a decent shrink be applied around your finished packs for a whole host of reasons...
Would anyone consider commenting on my idea of using my 48v10Ah lifepo4 charger (tops at 58.4V) for a lico lipoly pack?
I'm looking at my hobbycity options for a lightweight 10-15Ah pack for my next commuter build. My thread is here:
Charging 14S lico lipoly with a CC-CV 48v lifepo4 charger?
and only got one (helpful!) response from Gary (GGoodrum) but lipoly's a new game for me and I'd appreciate any further suggestions.
Cheers guys!
Both battery types use a CC/CV charger so it will work, but only if the peak current and terminating voltage are appropriate. A 14 cell lipo would typically have a 4.15 to 4.2 V per cell terminating voltage, ie to 58.1 to 58.8, so a 58.4 volt termination voltage would be ok. Assuming your pack is reasonably well balanced. Also assuming that the chargers current rating isn't too high for the charging rate of your new pack.
But personally, I would avoid charging with a fixed voltage charger. It's much better for your battery longevity, especially for lipo/li-ion to not habitually charge to max voltage. If you are doing a run that only needs 50% of your capacity, charge to say 80% full. Only charge to max voltage when you need full capacity which should hopefully be fairly rare. On the other hand, a fixed voltage charger going to say 4.15 v per cell won't let you use your full capacity on those times when you really want it.
It's possible to limit charging by using a timer in combination with a fixed voltage charger, but it can be hard to know how long to set the timer. Much easier to achieve a partial charge by setting a lower termination voltage.
Well said, and welcome to the thread / forum.
All correct and very good points.
Personally I always charge to near HVC but that is because I dont care as much about pack longevity and my goal is to have maximum range at any given time.
Those who know me well know that my pack will burst into flames long before it wears out :p
My theory is to keep the bike charged up as much as possible all the time so I charge at any opportunity - at work, at lunch - whenever.
I also charge at 3C when possible so that in only 20 minutes I can top off.
-methods
The charger he mentioned is a CC-CV lifepo4 charger so it should be fine for the lipos.
I posted a few other comments to your thread voicecoils.
Sometimes I think you're trying to make your packs burst into flames :lol:
methods said:
GCinDC said:
my ghetto, but hopefully dummy proof solution:
with this:
You MUST glue the backs of those JST-XH 6P connections.
Those pins are just pushed in there and they will back right out on you.
Run some CA jell along the row of pins coming out.
Even if they feel snug right now, the first time you run 2A though those they will loosen right up.
Your worst nightmare is *thinking* you have all the cells paralleled up when you dont....
-methods
hi methods I found the post you said use CA jell i presume this is cyano or superglue I could not find any jell but found thick about as thick as cough syrup, I have the activating spray will that work to keep those balance wires in place in the housing do you think without insulating them.
Geoff
methods said:
Geoff
6P = 30Ah . . .
10S = 37V
-methods
hi
thanks for that, as long as I can charge overnight I am not bothered.
if I have to do some more custom settings how would I do that?
I have found the safety timer and the capasity cutoff settings in the 1010b menu what do you think I should change them to?
Geoff
Status
