bronz said:Why did you decide to design and build a controller zombie? Was it for the fun of it or does this new controller afford you better performance or something? Just curious.
that's an interesting way to phrase it, ha!Designing a good gate driver layout is like trying to solve a difficult 3d puzzle.
Lebowski said:is there a schematic somewhere ?
Lebowski said:HAVE A LOOK AT THE CURRENT SENSORS, IN THE SCHEMATIC THEY'RE THE WRONG WAY AROUND !!!! OUTPUT STAGE MUST BE ON PIN 4, MOTOR ON PIN 5
A guy with your training should have no problem affording itHighHopes said:i'm jealous of your scope
Arlo1 said:Zombies the current sensor will only work one way.... You might need to cut the traces the do it the right way. What sensor is it? Is it the Honeywell we got from big moose? If current goes though the ferrite core one way the voltage increases and if current goes the other way it will make the voltage output decrease.
Yup lets have the link.zombiess said:Arlo1, if you are interested in going to isolated supplies on your next design, I found a supplier in China that sells the same kind of 1W 24v-15V unregulated supplies for about $3 each, I was thinking of ordering some for future projects. Even if I only use 2 isolated supplies for an entire controller it's superior to boot strapping and makes the layout easier. Found some 2W units for $7 each, these would be good if I only want to use 2 supplies for high / low of an entire controller vs the 6 I am using now.
liveforphysics said:$12 for an isolated 5w. Come in various voltages and a few higher and lower power levels. All pretty cheap with decent specs.
http://www.futureelectronics.com/en/technologies/electromechanical/power-supplies/ac-dc/Pages/7039474-PBK-5-24.aspx?IM=0
zombiess said:Lebowski, will having this length, ~2.1uS, of propagation delay effect your controller at all? I am only planning to switch between 6-15khz, maybe 21khz if I want to try a really low inductance motor.
So you tell us you have something but you don't let us see it or the link to order it???zombiess said:liveforphysics said:$12 for an isolated 5w. Come in various voltages and a few higher and lower power levels. All pretty cheap with decent specs.
wrong type LFP, we are talking DC-DC converting 24VDC to 15VDC for the gate drive with an isolated unregulated converter. My setup is designed to run off of 24V which will be regulated from what ever battery voltage I end up running.
Arlo1 said:So you tell us you have something but you don't let us see it or the link to order it???zombiess said:liveforphysics said:$12 for an isolated 5w. Come in various voltages and a few higher and lower power levels. All pretty cheap with decent specs.
Allegro ACS758 200A inline sensor.
HighHopes said:Allegro ACS758 200A inline sensor.
zombies, be careful about the sensor. read the datasheet to get the exact part number, you need the version that is Bi-directional as your phase current alternates between positive & negative values.
with Bi-directional sensor, then, maximum positive (peak) current is given as 5V at output of sensor, 0 Amps is given as 2.5V and minimum negative (valley) current is given as 0V. hopefully your brain board is expecting something like that and/or you have adequate signal conditioning path that can make the translation (as well as filtering as required).
measure your spool of wire for inductance value (you have this feature in handheld meter correct?). calculate approximate ballpark you need by I = L*dv/dt. I = current needed to trigger your desat under normal use (200A?, i forget what we designed it for). L = your spool of wire. dV = allowable voltage drop of DC Link cap during this test = 20%, or 0.2 * test voltage = 0.2 * 50V = 10V. dt = lenght of time of individual pulse (use 50% of your target switching frequency, so for 20kHz switching then 25uS is time to use in your calculation).
