Zooom programming apk for Bafang help?
adwb
🔌 New-ish
Bristol
I have a Bafang uart controller with a g062 750 watt Bafang hub motor.
using zooom on android phone I have every thing working ok except ;
1 even with the pedal sensor type set DH sensor 12 (twelve being the correct magnet number) and the slow start set to 4 and start degree to 1 the crank goes past two or more magnets before motor starts. Start current is on 20%
2 using a 500c display the watt meter on the left has to reach medium before the motor suddenly stays to pull hard. This ok but I would like that power to ramp up earlier. What do I change to get that? Start current is on 20% which gives a nice soft start , but is low to increase power.
thank you.
