Thanks, believe I have the hall and phase order correct. Same motor and gearing as before but the motor no runs hotter.
Same controller, too? Different controller = chance of different design, wiring, etc.
If new controller has higher current limits, then it allows higher power to the motor for loads high enough to draw it, which also heats the motor more, especially if gearing is not correct for that load. (in this event, it wouldn't have heated up before because of the lower current limit of the previous controller).
Had one guy say he did a hall angle test with a Votol that would and ended up at 53°. The magnetic ring is just pressed on the motor shaft to can see how there will be a variation. I was thinking about a oscilloscope to try and plot the shift but just have a ghetto single channel. Backed it off to 55° and no difference in sound but runs cooler.
Some thoughts and general motor information below:
Magnetic ring? Do you mean the rotor, with the magnets that operate the motor, or a specific encoder ring?
If it's a specific encoder-only magnet ring, then there are multiple types of output that a sensor reading such a ring could have. The most common is SIN/COS, not UVW; if interested you can look up the other encoder types. If it is not a UVW encoder, like standard halls that read the rotor magnets, then the hall/phase order doesn't exist, because it doesn't operate that way. The hall/phase order only applies to UVW hall sensors, where there is one sensor for each phase; if it's not a UVW encoder, then most controllers can't read it and won't operate the motor correctly if at all, unless they are sensorless-capable, because they
It could still be a UVW encoder, where they have magnetized the ring as a series of opposing-polarity strips, with three hall sensors placed at either 60 or 120 electrical degrees around the circle, (or some other angle, though that angle would be the same for all motors of that design, so the manufacturer could tell you exactly what it is--it should in fact be in the motor specifications).
In this event, if the ring is correctly installed, it should always be at the same relative rotation angle as the rotor magnets, aligned with them. If it is not, but instead is either intentionally installed offset or just randomly installed at the factory because they dont' care, but the hall sensors that read it *are* always at the same install point (bolted to the motor frame, etc), that's where an "angle" could come in, which is advance or retard angle, the number of degrees positive or negative from centered / aligned with the rotor magnets.
If the offset is intentional, then the motor manufacturer can tell you what the angle is, and again it should be part of the general motor specifications available from them, because it would be the same on every motor.
If it's random because they don't care how it's installed, then it is up to the user to figure out on every single motor they have what each motor's offset (retard/advance) angle is. This sounds like where you are at.
