Hello all
I am a first time builder of a hub as I purchased a 26 inch hub motor instead of a 24 inch one. Its hard to find hub motors that size that would ship in a decent time so I decided to purchase spokes from Grin Technologies and a 24 inch rim from either there or somewhere else. I have used their spoke calculator as well.
They have several rim types and I am not sure which one to get. I was looking at the crystalyte one but the infamous Chalo was saying its rubbish.
I also heard weinmann isn't that bad.
I then heard the Halo rim is the bees knees. While I respect the price of 69$, that combined with the lack of a rim profile on grin is going to make it more expensive and more of a headache. While the ERD and rim width is provided, I haven't been able to find any information on the left and right offsets for it. If anyone has one and can provide them that would be great.
tinyurl.com
The rim will be used on a front loading cargo bike. The rear hub motor is 2000w 72v.
So my first question is how much should I be stressing over the rim, and which one should I get.
This is my old rim, 26 inch. Also its worth nothing that the axle doesn't fit in the dropouts, so I tried bending the frame with some but not enough success.
I am worried that the torque of the hub might be too much for the dropouts as well. Would like some opinions on this.
I've purchased the 24 inch halo rim, and I suppose brought the thing into dish.
Right now I am concerned that the wire exiting the hub motor is too close to disc brake mounts. Any suggestions?
UPdate@
______________________________________________
We have been running, I've limited the power to 48v, up to pas 4 max out of 5. At pas 5 we get around 36-38mph top speed.
We have done 280miles on the odomoter with no signs of wear to the dropouts.
Now we have another issue. No suspension on a bike like this is brutal. I increased the size of the tires but its too wide for the seat stay. I have been playing around with the idea of unwelding and welding to the bike but I am not a welder. I don't know if I should try to pay someone to do the weld or of I should buy a welder, learn how to weld and do it myself.
If I were to do the welding myself, any reccommendations on a mig welder? Tutorials, etc?
If I were to outsource the work, would it simply be better to entrust this to someone who knows what they are doing?
My bike is certainly steel. The length of the seat stay bars are 13 1/2 - 14 inches.
Theoretically I would love for this bike to support 4.0's in the back, which would require me replacing both the seat stay and the chain stays, but that would be more complicated to do I assume, but would it be worth it to just do that now instead of just expanding the seat stay?
1) I want to expand the seat stay bars so it can support a wider tire
-This involves cutting the current seat stay bars off, then welding wider bars.
2)What type of steel should I use for something like this? I know there is mild steel, stainless steel, stronger steel with various numbers. I assume that I don't have to match the type of steel exactly? I don't know the specific type of steel my bike is made from.
3)Where should I source the steel from?
(I've been trying to do a lot of research on this, and have found various websites, some of which want you to ask them for a quote) Columbus Zona fatbike seat stays - 19 OD - .6 wall - length = 560 I was looking at this one but honestly I have no idea what I should buy. I want it to be heavy duty asf, weight is not an issue. I know that the tube is hollow so you obviously need to taper the end to fit the dropout.
And finally my new paranoia are these two tubes. Especially after the babboe situation...The vertical one goes to the handlebar, but unlike other bikes of this type, it doesn't have a supporting upper tube, I wanted to weld a bar going from the vertical tube to the seat post tube but I realized its threaded on that lip there, so some other options would be ideal. Also if anyone has a solution or a size recommendation to attach a spring to the kickstand so I don't have to use the bungee cable that would be great.
Halo SAS 24 Disc Rim 36h - Black for sale online | eBay
Find many great new & used options and get the best deals for Halo SAS 24 Disc Rim 36h - Black at the best online prices at eBay! Free shipping for many products!
UPdate@
