Thanks a lot AndreyPr for your work !
It looks very good and worked well for me.
However I think I did a silly thing.
I used it to tune my external 22A controller that came with the H640 Bafang hub motor (750W geared).
I know the tool is more oriented towards middrive with internal controllers but I decided to give it a try.
Initially I wanted to fix the following issue: my motor is triggered by the PAS even when pedaling backwards, instead of only forward.
So I played a bit with the "Pedal sensor type” to see if 1 of the 3 options would solve it.
When first reading the parameters, it displayed DH-Sensor-12, so I tried BB-Sensor-32 and DoubleSignal-24.
It did not solve my backward pedalling issue but instead it broke the PAS detection at low rates. Now I need to pedal at more than 50rpm before the motor assistance starts!
Unfortunately, going back to the initial setting does not change this new behaviour and using "none" (which should disable the PAS) does nothing different.
My assumption is that the factory setting for "Pedal sensor type” on this external controller was something different than the 4 options available in the software, and therefore I cannot go back to the original state.
Do it makes sense?
Any idea how I could fix that without buying a new controller?
I can only blame myself and I would greatly appreciate any advice from more experienced members
If it is of any use, the Info page reads:
- Model S106
- Manufacturer HZLD
Firmware version LDCBB107U4822B1111356.1
