Theres alot of fun to be had on the most simple of rides, adding a little fizz to the mix when possible can increases the smiles per miles ratio as long as the build goes to plan.
Well ive had lots of build not go to plan and got a fair old box of random parts and when i seen this bike i knew this could thin that box down a bit while creating a wicked ride.
Theres a bike local i pick up on the weekend for a fair price good as new, im going to gut its near new electronics after i have a tear up on it and add a qs 138 70h i got sitting idol.
Mating the motor to the wheel thats using a disc brake iso for sprocket attachment has never been easy theres a few 219 sized sprockets about but the qs motors sprockets start at a chain size of 420 and up.
420 and 428 kart sprockets exist but they have a teeth range of 40 to 54 on average and with a mitor sprocket of 10t not many rides could gear down enough for the wheel size but the small wheels on this will allow me to go direct drive with a 5.4 ratio thats very close to stock with the ability to climb to a 3.6 ratio just swapping drive sprockets.
In my parts bin i got an oset sprocket carrier thats disc iso pattern to kart 135mm pcd sprocket, from there ive got a 54t 428 sprocket so i can mount the qs motor and have a direct drive with the chain tensioned through the mount no need for chain rollers so no issues applying regen.
As for the controller im not to sure but ive got a vesc i can get it running with till i battery swap it and get something more suitable when i got some dimensions to work with but will properly go with a votol 200 2sp.
More updates coming soon.
