new tsdz8 pswpower
Thanks. I'll need to take a closer look. The kit came with an IT4 cable, so 9 pins at the motor, then splits to 2 brake switches, throttle, and 5 pin display.
Took a look at pswpower, and i think this kind of confirms, that their displays are compatible:
TSDZ8 TSDZ2B TONGSHENG EKD01 Bluetooth VLCD5 vlcd6 850C B02N VLCD13 VLCD10 XH18-LCD LCD Display for Electric Bicycle Mid Drive Motor
Unfortunately they don't carry separate displays in the USA warehouse, just tsdz2/8 kits.
Thanks, I saw that one too. It’s i miracle, but after over a week in customs, it’s finally moving, so it may actually ship and arrive if things go right/better.
Why was it held up in customs (China or US customs)? Will you be charged tariff?
Not sure, but doesn’t look like it. Crossing my fingers. I learned a little bit about Amazons policies, and how they indicate (or don’t) whether their vendors might be importers, etc. Bottom line seems to be you need to do your own checking to avoid being hit by fees after the fact, even when buying from Amazon.
Hi everyone,
Niki Baker who has a TSE contact on the FB group some time ago declared that they are working on the option of user configuration of TSDZ8:
What do you guys say to ask them from time to time how the work on this is going? 😅
I think that putting pressure on this issue on the official FB group can speed up the process.... How about it? Do you find a moment to write a question on the group regarding this? Let them feel our breath behind their back ;)
I already took the first step a month ago, pressure always makes sense guys! :mrgreen:
Hi everyone,
I only see that he mentioned upgrade process and not user configuration, and actually motor firmware upgrade via Bluetooth from the display (DFL-11) is already possible. It is only signed firmware so no custom ones.
Hmmm, I have the impression that they also mentioned the configuration somewhere, anyway - let's ask them! ;)
We're going with pressure on guys! 💪
Requests to get something for free + made up pressure == i'd give the middle finger to anyone begging like that.
For free? Is it the engines TSE is giving away for free? Ehh, and I stupidly paid for it :(
Also, I guess you didn't read my previous post with the link to the first post on the FB board, let me quote as a picture:
TSDZ2B TSDZ2C TSDZ8 TSDZ16 Mid Drive | Hello! | Facebook
Leave the middle finger to satisfy the corporations, they will probably be grateful that you are doing them good ;)
This subject might be good for starting a new thread in the vendor relations corner subforum. Power to the people!!
Oh, I didn't realize they were representing TSE. Thought this was some 3rd-party thing.
@aae34
Niki or Perry once wrote that they don't work there BUT, they test for TSE their products before they go on sale, they have direct contact with TSE designers and engineers and that's a lot :)
In any case, the more Niki and Perry see configuration requests on the group, the more often they will mention it to TSE the next time they visit them ;)
In previous posts I have seen that some of you had problem with osf vlcd5 display- showing battery only one level and motor not working. Did you find a solution to this problem?
I have tried to flash with 860c firmware and with 860c display motor works. Still would like to use cheaper vlcd5 display on my commuter bike.
After converting 4 bikes to e-bikes, and cycling over 1500 km on my recently converted B'twin Rockrider ST520 with a Tongsheng TSDZ8, I would like to share my installation process and do's and don'ts. My previous conversions are using the TSDZ2 motor. These bikes I built for a few friends, are all are still running strong. One has done almost 10000 km. None of them had any issues. But this TSDZ8 on my most recent project is a different animal. Much better construction and way more powerful. Until now it’s been really great to ride the bike.
I ordered the TSDZ8 motor with the B02N-TS display, and a 48V 20Ah battery in Hailong Max enclosure from pswpower.com in March. I received the materials within about 1 week, very well packaged and it was delivered complete with cables, throttle, brake handles, all screws, spacers, etc.
Installation:
  • Remove the old chain, cassette, bottom bracket, front derailleur + shifter, and rear shifter cable.
  • Assemble chainwheel on motor, mount motor on bike.
  • Install chainguide or re-use front derailleur without cables (use adjust screws to set position) for keeping the chain on in lower gears. Chain will drop otherwise.
  • Mount new cassette, install new chain.
  • Mount crank arms and pedals. Torque the crank arms down really, really tightly since the arms tend to come loose if undertorqued.
  • Install rear shifter cable and a full-length outer shell.
  • Install battery. Use M5 threaded blind rivet nuts to create the mounting points in frame if needed. I had to make these mount points.
  • Install display, route cable to motor.
  • Install brake levers and connect to display cabling.
  • Connect speed sensor and bike lights.
  • Update motor firmware to test_3.0 from august 2024 using a Segger Jlink programmer. This firmware has the best riding experience and is bug-free (for me at least).
Do’s:
- With a flat piece of wood and some 180 or finer grain sanding paper, remove the paint from the sides of the bottom bracket, where the locknuts of the motor will press against. This will greatly reduce the chance the motor loosens (paint is soft and will deform, so loosen the motor).
- Use extra-strong green Loctite on the following places:
  • Both motor locknuts threads. Before applying, remove grease with some soapy water or brake cleaner.
  • Between the bottom bracket walls and the motor mounting plate (the small black metal piece). This will improve the torque handling. Degrease before applying.
- Place a polyethylene pad between the motor casing and the bike frame down tube. During assembling, rotate the motor such that it already presses firmly against the pad (so motor points to the front of the bike). After that, torque down the locknuts with a hammer and the provided locknut wrench. This method avoids motor rotation and guides the reaction forces through the frame rather than through the bottom bracket.
- Use a piece of old bike inner tube around the motor wiring harness where all connectors are. This protects them from the majority of dirt and water ingress.
- I removed the AMP connectors from the battery cables to the motor and soldered everything at exactly the right length once all was mounted. I kept the yellow XT60 connector at the motor side to ease removal/servicing of the motor.
- Adapt the charger maximum charge voltage to 52V (4.0V per cell) to greatly improve shelf life. There is a potentiometer in the charger to adjust this voltage level. Use a multimeter to make sure the voltage does not exceed the max charge voltage. You'll lose about 20% of capacity, however the battery will easily last >2 times as long as it degrades much less over time. If you do this, it's important to still ensure the balancing us activated once in a while and this can be problematic if your BMS starts balancing only at 4.0V or higher.
- Ideally, charge the battery only just before when you're going to use the bike, and only charge it for the amount you'll need for your trip. Avoid charge levels above 52V (80% SoC) when you don't need the range that day.
Don’ts:
- Don’t route any cables (signal, power or shifter cables) underneath the motor to avoid cables being squashed when the motor accidentally gets loose. This surely can happen - happened to me and it destroyed my display cable connector. There is some room on the non-drive side to neatly route cables.
- Don't charge your battery to 100% full every day or park the bike with a 100% charged battery. This will cause about 15% to 20% yearly degradation by just letting it sit at maximum state of charge. One of my previous builds still has 90% state of health even though the battery is 7 years old and has done 7000 km. Limiting charge levels and charge time really helps a lot.
I posted this to the TSDZ8 Facebook group as well ;)
Most BMS systems perform balancing at 4.15v per cell and above. I would just charge to 100% at least once per month to avoid any potential issues.
Instead of trying to once again over torque the life out of the motor locknut (started to loosen again, this time after 2500 miles since the last time when i used a 3ft extension and killed the OEM wrench :D ) I tried adding this m5 bolt and custom nut i made from aluminium flat stock to the vacant bolt hole in the motor mounting plate. Its has potentially a lot of force to deal with, but hopefully its mostly shear force going through that thing.
This solution of course won't work on most standard bike frames, this is a Giant Revive so everything its weird on it.
The motor has now been in use just over a year, I've put 4200 miles on it in that time, still seems to work as new. I rode 1000 miles during the admittedly unusually mild winter in Southern Finland, still quite a few freezing temperature trips, no issues.
I got the 48v version two weeks ago and it certainly doesn't have the problems reported about the ones they were selling at first. I haven't put the J link on it yet so I can't say if it's the newest version of firmware. I have the B02N TS display that shows five levels of assistance. First level is a bit stronger than my tsdz2b with osf in hybrid mode. The start assist is really too strong, the overall feel isn't as natural as the 2b, in that you feel the motor's presents a lot more. There are occasional irregularities in the assist power, but it's quieter and stronger for sure as I go up the hills on my normal route at 15 or 20 kilometers per hour when with the 2B I was going at 8 to 12 kilometers per hour. The difference is between the assist levels are noticeable but perhaps not as differentiated as with the OSF in the 2b.
You didn't ask but I'll add a few more details about the motor. The q factor is wider but on my recumbent that's not much of a problem. I bought a 38t chainring and adapter from AliExpress for the bafang and with the Dremel modified the mounting holes to fit and so far so good but I've only been on one longer ride of 45 km. So you can see so far my experience of the motor corresponds to the information you can find on this forum. It's stronger quieter and seems to be better built, but I hope the development of the OSF catches up to the tsdz2. I have three of them and I'm quite happy with them, with just one problem with one of them very recently. I think the clutch on the drive went out, or it might be the white gear.
I obtained z8 with VLCD5 from PSWPOWER a few weeks ago and in my case all 4 assist levels offer comparable strong assist level, you cannot tell any difference between them. Throttle is living it's own life :)
that's why I bought a tsdz2b and installed OSF on it... in the most cases brain play a bigger role than strength...
can i use 52 volt battery with tsdz8 without problems? will battery percentage work normally ?
I have 52 V battery and it's working fine. I don't know of percentages I use volts. On display bars go red and disappear long before battery is empty. I use 860C display,
