After more than 1.5 years of work and lots and lots of setbacks, I finally finished my CLWB (Compact Long Wheel Base) fully. The whole process started years ago, when personal health limitation forced me to look for alternate bicycle design. Than I came to realize there was no bicycle available meeting all my requirements. All I wanted was a stable, comfortable e-bike with a backrest that is as low-maintenance as possible, has a solid luggage rack at the front and still fits in the car if required. So I started drawing stuff in Blender and step by step made it all the way to this bike. The biggest help was by far the framebuilder who had tons of experience with alternate designs, but the entire project would not have been possible without the many little gestures and advices from people all along the way.
So far I've ridden slightly over 200Km and can't stress enough how enjoyable it is: most semi recumbents come with some sort of bent steerer which make steering awkward. This bike comes with a straight direct steering tube, which makes it super reactive. The flat steering angle comes with the additional benefits of allowing a generous font rack and a large front wheel trail, which increases stability as you go faster, just like a harley. The front fork is a regular 20" suspension one, compatible with most models on the market - proving hereby that it's actually possible to design a CLWB without using some exotic small front forks and wheels. The rack is very handy, and allows up to 25Kg of luggage, this also increases stability, especially on lose ground. Another common issue is the very long chain going from the BB to the rear wheel. This bike solves that problem by splitting it: front transmission is a clean belt, so no need for chainguards, and the rear transmission can be a chain .. or a second belt, since the middle jagshaft is concentric with the rear suspension axle: works very well!
The electric part took longer than expected: while the battery was no real issue since I designed the frame to clamp it down, the vesc controller proved more of a challenge. Like many here know, the key problem is the display. You can write a custom lispBM script to communicate with almost all chinese ebike displays available, but those are often sluggish and don't show the information you need. So again I started from scratch and programmed my own display. Luckily there are plenty of knob style displays available nowadays with decent screens so I picked the best amoled with a reasonable size and coded an lvgl based gui: looks good and is very reactive. Also, it allows for CANbus or uart communication which might come in handy, and since it packs an esp32s3, future possibilites include OTA and remote control of the vesc.
And last but not least, one might wonder where that funky motor comes from. It took me a while, but I found a chinese manufacturer that still makes Direct Drive hubs with integrated geared hub. Getting a sample proved near impossible, so I looked for a used sparta r5te bicycle and found one in the netherlands. Had to convince the owner to send the motor only via international shipping all the way here but it worked and I finally had my motor. Than I realized there were no halls and the stock cable was garbage. So I opened up the beast - which helped confirming it had 34 Poles - added 3 halls, a temp sensor and soldered a L1910 cable, before lacing it again into a 20" rim. And look, now it's working!
Next step would be marketing: should enough people show up that are interested into the CLWB, I'd start a first series, maybe to be sold as framekit.
Flixbike Fully CLWB - 2024
Design: Felix "qwerkus" Schalck, felix.schalck@gmail.com
Framewelding: Sebastian Lindler, seli-online@gmx.de
Tires: 20x2.6 front and rear
M sized frame for 1.65-1.85m people
Seat height: 72cm
Wheelbase: 1420mm
Total length: 1950mm
Weight: 22.5kg without motor
with direct drive and 104cell battery: 35kg
Frame: CrMo4 + stainless steel for vulnerable parts (dropouts, for example)
Suspension travel: 80mm front and rear
Seat: Van Raam
Fork Spinner 300 AIR
Shock: SR Suntour
Brakes: Shimano
Drivetrain: Front Gates CDX, rear 1 1/8" chain + 5 speed SA IGH or 7 speed shimano IGH
Electric:
Motor: Nantong-Leisheng direct drive with integrated hub gears, 34 Poles max power (short period) 1.5Kw, continuous 500-700W
Battery: 48V 104xSamsung 35E cells = approx. 27.5Ah or 1.32Kwh
Controller: VESC with own-programming
Display: custom made 1.5" Amoled knob display with rotary encoder.
Folding mechanism: Remove the center shock and tilt the swing arm forward, then remove the wheels as required, pull out the seat and handlebar extension and remove the fork + rack. Completely disassembled, the bike fits into a 95*70*40cm box.
Seat height: 72cm
Wheelbase: 1420mm
Seat: Van Raam
Shock: SR Suntour
Brakes: Shimano
Electric:
