thundercamel
Regular
Thanks Chalo, Good to know you haven't seen steel ferrules either. I at least did learn to grind the housing ends flat from Sheldon Brown in time for the repair.
Looks like I forgot to mention that I helped build another eBike in April; this time for my wife's stepdad whom I get along well with. I sent Tom a few used bike listings that would have made good conversions, but he wanted something new. This is what he picked out from Walmart with my approval (the first one had tiny stanchions, which was the main problem with my Walmart bike). The Sidewinder is the same as StefEbike, but two generations newer. I warned him that eventually these stanchions will bind up as well, but we can swap the fork out then.
We immediately swapped out the seat, handlebars and stem.
The motor, controller, and charger came from the black folding CEMOTO bike PHAT-E that I had recently upgraded. The spokes I recently purchased when I rebuilt the wheel in the other folding bike GoldiWatts, but then that bike also got a direct drive motor. Tom didn't mind the slower KV of the free geared hub motor. I wanted to paint the parts black, but never had time. The Sidewinder came with nice 2.25" wide tires, but the wheels/rims I laced the motor into are only about 20mm inside width. I would have been happier with 25mm or 29mm for wider future tires.
Since LG MJ1 cells that I like seem to be no longer available, I did research and chose Samsung 50E 21700 cells for longevity/cycle life again. This required me to buy new 21700 sized plastic spacers/cell holders, and the adhesive paper circle insulators for the positive ends. I was very mad when the price of the cells jumped from about $5 to $6.67 per cell right before we bought them, and now they're out of stock! I didn't take many pictures, but I used self resetting poly fuses on each balance wire for the first time. Wrapped the pack with smart JBD BMS in plastic sheet for protection, padding, and heat shrink. I also used new silicone insulated wire I bought. (No more speaker wire!)
The electrical performance is just like the original CEMOTO bikes were, but with a longer lasting battery. With only a 10s 36 volt battery, lower KV geared motor and 15 amp (500 watt) controller, it gets you up to 10 mph and then I saw only 20 watts on the meter by 18mph or so pedaling firmly. Back EMF! Tom mostly wanted the motor as a backup to get home if his health acts up at all during a ride.
Pretty fresh looking!
Tom followed us around Moraine Hills state park (McHenry Dam) and kept up with my speed racer wife quite well! He's been buying accessories since.
I bought a power meter for him, and he made this box for mounting the display. Tom also bought of his own accord the same head light and tail light that I've been getting, and wired them to the controller output himself with an inline fuse, connector and switch by the display.
Rack too. Hopefully he moves the light to the back of the rack like I did with PHAT-E.
I've been playing Farming Simulator 2013 with Emmett, and he pointed out the wheat
Bonus points if anyone recognizes this mansion. I don't expect anyone to be from my area.
