Hello everyone,
Thanks for all your work with OSF – really appreciate it!
I'm writing because I'm having an issue with the settings on my kid's bike. He is 11 years old and weighs about 55 kg.
The motor is a TSDZ2B 36V, and after opening the casing, I found the driver marked 36V 16A.
The battery is 36V 560Wh.
The problem is that the motor cuts assistance around 25–27 km/h.
We mostly ride MTB in the mountains, but sometimes we ride on flat asphalt sections where we cruise around 30–33 km/h.
That's the speed my son could manage even without the motor.
When we first got the motor, using the stock firmware, assistance was working fine even at those speeds.
I set the speed limit to 35 km/h on the LCD (B02NU), although I mostly use EKD01 as the display.
Now, here's what we've changed:
At first, we tested everything using the original 42T front chainring (from the motor) and a 12T rear.
But because my son had trouble riding without battery power (too heavy gearing), I replaced the front ring with a 34T.
According to my calculations, we’re not exceeding reasonable cadence values for that gearing:
30km/h - 85 cadence (rpm)
35km/h - 98 cadence (rpm)
40km/h - 112 cadence (rpm)
Here are the main settings, can you help me figure out what might be wrong?
The speed limit is set to 35 km/h on the LCD, and even if I set it to 40 km/h, the motor still stops assisting around 25–27 km/h.
I tested this myself riding his bike, and I can really feel the drop in assistance at around 27 km/h.
can you explain my what is means "set parameters on startup"?
Thanks in advance for any help!
Best regards
