chuyskywalker
🚴♂️ Mega poster
I've been on the lookout for an Eahora** M1PS Knight for a while. Found a guy on marketplace selling it "with a bit of damage", ha!
Pictures from the ad:
When I went to check it out, blown rear tire and FULLY bald, like 100% had been doing burn outs
Odo read about 2500mi, so they definitely got some good use out of it for the last 2 years ownership. Also owned up to laying it down a few time; nothing catastrophic, but clearly had to swap parts out here and there. I suspected that the amount of repair work just exceeded their tolerance.
Regardless, it powered on, motor spun with no issues, and I didn't see any structural issues with the frame. I won't know how the battery is fairing till I get it on a tester, but I'm not super worried about it. This was never tuned to higher amps, and it runs pretty "light" for something this big.
I paid $2400 for it and plan to get it back to fully working condition -- which, to their credit, Eahora does make pretty easy with a large collection of replacement parts available for direct order on their site. It'll set me back another $600 to get a number of things that I've found in need of repair.
Here's the fun fix-it list so far:
On a different note: one of the goofiest things I found in this kit is the ABSURD charger plug. It's a full blown "Mennekes (type 2)" plug and socket which only has two of the big pins connected with some 16awg looking wire. That wire then connectorizes into the main harness to get back to the battery with... an XT30 plug! I mean, the charger only puts out 13A, which is technically under "30", but it's pretty silly looking, imo. Plus, it gives off the very wrong impression that you can take this to an EV station -- that would go poorly (not that anything here in my region uses this connector type, but still).
One really nice upside: this is already registered with the local authorities, so I just need to get it transferred and I have something legal to ride, right out the gate. That's a big plus for me, and one of the reasons I was attracted to this particular bike. We'll see if this project derails my fargrin build; there's some very good reasons to scrap that project and move the 96v system onto this one...
Now back to my tinkering as I await parts to arrive.
** Eahora is the US rebranding of Mangosteen in China.
- Rear tire fully wrecked, replacement ordered
- Rotors are pretty well used, has rust; replacement ordered
- I don't know the condition of the brake pads, but out of an abundance of caution; replacements ordered
- The "tank" has one of the bolt bosses of plastic broken off; repaired with ca glue + high strength plastic epoxy to build up some support
- The keyfob receiver was held on by tape which had dissolved over time; replaced with new doublesided tape
- Original rear fender wire loom clearly spent some time rubbing elbows with the tire and was worn down to bare wires; ordered replacement
- The ignition lock lost some retaining screws at some point and the constant motion caused the negative connection to partially separate; depending on which way the steering was turned the bike would turn on/off as the wire made/lost contact; will repair/replace
- The charger had something rattling around inside; cleaned out some broken off plastic retaining rings and vacuumed out about 500 small bugs
- The headlight is, reportedly, under-powered; will investigate
- General dust-and-grime cleanup needed; rag and cleaner solution deployed
- The left brake lever got a good chunk scraped off, but it's not bad enough to warrant replacement, just cosmetic
- DC breaker was knocked loose from mount and looks to be in rough shape; replacement ordered
