Things have progressed, but with a lot of "dealing with reality"'s.
First, the battery case got made up. Polycarbonate sheets and some weld-on4 tack it all together. The top piece is a two part 3d print with some heat set inserts to bolt through holes drilled in the case sides.
I used a 3d print that wraped over the sides and had marker'ing holes for where I would need to drill out:
Worked mostly well. Later on I found the holes not quite perfectly aligned and needed to drill out a few a step or two higher in the bit set. Not the end of the world, but certainly another excuse to get a CNC again so I can cut out my own sheets and all the features needed therein.
(Would be have been especially helpful on the "divots" I needed to make on the bottom of the case where the tubes began to angle up early and I needed the rest of the bottom to sit flat.)
Frustratingly, though, the box ended up hitting the main support beam of the bike. On the bright side, the walls were extra tall on purpose, which gave me some wiggle room to adapt. With the help of a set of ever enlarging router templates:
I was able to trim down the rear wall to fit nice and snug around the bike. Honestly, it's kinda cool and really makes it feel like a part of the bike, instead of something just slapped-n-strapped in.
Once that was setup, it was time for
allll the test prints to validate the lid. Does it fit side-to-side (no, make it a bit wider), do the bolt holes line up (they did not and needed slight positional tweaking), do the round-overs match (they did!), etc.
Many prints later, and it's fitting good enough. It's definitely not perfect, but it fits well enough that I can move on.
I had some quirky problems with the BMS that required some reflashing to get it to the latest version (early adoptor standard fare), but that's otherwise sorted out it seems.
I still need to drop the battery in the case and get it "locked in". Both internally and externally. Inside, it's going to need a good bit of padding. Externally, I need to figure out how it attaches to the bike. Right now, I'm leaning towards printing something I can screw onto the bottom-front of the battery that will dip below the tubes it is sitting on to prevent side-to-side motion (prevented in the rear by the cutout) and then maybe...a strap to keep it held down? Some bolts from the bottom would be better, but not quite sure how to rig that up yet. Though, I do think some support along the middle of the case in the bottom tray would be advised (even though I'm pretty sure the 1/2" thick polycarb would be fine).
Really big next steps are going to be the controller, display, and maybe this new fancy thing VESCLabs released, their "remote"
RMCore which let's you bring controls in at the RMCore location (throttles, lights, switches, etc) both input and output, and then canbus that data back to the controller. Helps clean up wiring. Not sure it's for me though, honestly, because should have plenty of wiring space since the 3 phase and 2 power cables are no longer in the hidden tube run.
