Looking for 9-Pin Female Connector for CZJB 110SZ Hub Motor (2.0mm Phase Pins)
jfamiglt
New here
USA
Hi all,
I’m trying to source a 9-pin female connector/extension cable for a CZJB 110SZ hub motor. Some important details:
  • The motor uses 2.0mm phase pins (larger than standard 1.5mm).
  • The Hall sensor pinout may be non-standard, so wiring order could differ from typical Bafang/Higo setups.
  • I’ve searched AliExpress, eBay, and Walmart, but haven’t found a compatible pre-made cable.
  • CZJB does not provide or recommend cable suppliers, and local bike shops are unfamiliar with this motor.
My goal is either:
  1. A ready-made 9-pin female extension that works with this motor, or
  2. Guidance on sourcing the correct connector housing and pins to assemble a custom cable.
If anyone has experience with CZJB motors, knows a supplier, or has fabricated a compatible cable, I’d really appreciate your guidance. Photos, part numbers, or links would be especially helpful!
Thanks in advance!
it looks like a regular plug but the 3 phase pins are much bigger (2.0mm) not the usual 1.5mm
