to7motor@SZ
🔋 Established
Regarding the feedback from our global community concerning the recent firmware optimization for the DM02 (500W), we would like to clarify that our firmware updates are not arbitrary limits; they are the result of exhaustive laboratory stress testing and real-world durability data.
Our engineering team has moved the DM02 from a raw amperage-based logic to an optimized torque output model. This ensures the motor operates within its most efficient mechanical range.
This optimization reduces internal thermal stress by approximately 25%. For riders, this directly translates to better range and a significantly lower risk of controller or gear failure, especially on 52V high-voltage setups.
Performance Data Summary:
TOSEVEN Engineering Team
1. Voltage-Specific Calibration
Through Dyno testing, we have identified the optimal efficiency point for different battery platforms. By standardizing peak current, we maximize torque while minimizing energy waste.- For 48V Systems: By standardizing the current to 14A, the DM02 achieves its maximum peak torque of 102.5 N.m. Our data confirms that at this voltage, 14A is the threshold required to reach the motor’s physical torque limit without hitting magnetic saturation.
- For 36V Systems: We have calibrated the current to 18A, delivering a stable 91.1 N.m of torque. This ensures consistent performance during sustained climbs while reducing the overheating risks associated with unregulated 20A settings.
2. Efficiency and Thermal Management
The DM02 now reaches a peak efficiency of 74.3%. By preventing "over-current," the system converts more battery power into force and less into heat.This optimization reduces internal thermal stress by approximately 25%. For riders, this directly translates to better range and a significantly lower risk of controller or gear failure, especially on 52V high-voltage setups.
3. Reliability Standards
While previous firmware allowed for manual adjustments, our global service data showed that unregulated "overclocking" was the leading cause of drivetrain wear. To support our Global Warranty and ensure long-term reliability, the DM02 now manages power delivery automatically.Performance Data Summary:
- 48V System: 102.5 N.m Peak Torque @ 14A
- 36V System: 91.1 N.m Peak Torque @ 18A
- Thermal Stress Reduction: ~25%
DM02 500W 36V 18A
DM02 500W 48V 14A
