No further spoke problems, however, the problem fo the skewer loosening has returned.
Based on the design of this hub, it should not be the same progblem as the previous, where the inboard cups of hte bearings relocated inward under the skewer tension and the sideloading the front wheel experiences in turns. This one has bearing modules, with a cylinder between the inner races to prevent taht kind of relocation. So I am not sure what is causing it. It shoudln't be skewer stretch or skewer barrel "cup" compression; these are metal.
it has happened only once so far in all the time since changing the wheel, around ten months. So it could be some other cause than the previous one (someone messing with the wheel while I am at work, for instance, as unlikely as that is. (The trike stays in our breakroom, whcih while that doens't prevent access to the public, deters it. ))
I am looking into replacing the entire skewer and hollow axle with a bolt and nut.
Separately, when i changed all the tires out at the same time (first time for that, they all happened to be worn enough around the same time this time), I had problems with the air pump I've been using for over a decade. The motor is not very good, and was not wound with thick enough wire to start with, so it has visbily overheated over time. it sitll works, but it had "that smell" when i was airing up the second of three tires during this process. It's a crappy harbor freight pump, cut down from it's original casing whcih included a crappy SLA battery, to just hte minimum plastics needed to keep the pump and motor itself enclosed, and h old the airgauge and switch, and more ventilation than the orignal had. Heck the motor is so weak they even instaleld a plastic fan on it. :lol:
So I dug out an ancient 1980s Sears automotive compressor meant to be kept in your trunk with your spare tire, etc., that when she was still around my mom had bought (new...) for her car. I've kept it as a spare, but the hoses inside and out rotted away (no surprise after four decades). So first I had to cut the casing down, taking over an inch out of the middle, so it would fit in the trike's toolspace.
I replaced the hoses with reinforced fuel line; those are heavier but also are unlikely to fail.
Unfortuatnely I have not yet found an acceptable and affordable air chuck for the valve stem end, so I am using the crappy right angle lever type off the HF unit. I don't like the style; it is hard to use, and it is hard to fit between the stem and the hub's spoke flanges on the rear 20" wheels.
I have previously tried several types of 90-degree adapters for those, but they all leak, and having ot install them just to air things up is too anoying, and it also causes more air loss as i take them off afterward, usncrewing them as they hiss my air away.... so i stopped trying those things. :/
This is the chuck type I would prefer to use,
That particular brand has a good gripping mechanism, but it requiers putting the chuck straight onto the valve stem. can't do taht on my wheels. This version
is too tall to work, too.
So I want to use a ball style angled one like this, but with those multi-jaw grips, but the company doesn't seem to make one.
I don't want to use the little guillotine on just one side-this type does not hold onto the stem straight so I have ot keep holding it in place anywya to keep the seal, making the entire lcoking mechanism almost useless.
I'll settle for this style if i ahve to, but haven't found one that already has a 1/4" barb inlet, or a cheap one with a threaded input and a cheap 1/4" barb inlet to matc that thread. So far the bits I want are all sold separately, in packs of two ro more (only need one), and getting just one each is twice as expensive, or more, or four times as much for each part. So it's looking like 25 to 50 bucks total just for teh chuck. No thanks.
I also replaced the skinny power wires to it (12v lighter plug style) with the better ones off the HF unit (which I think I had pulled off something else when i reubuilt that one back when..).
I kept the sears gauge on it, which turns out to be accurate. I did not realize the HF guage was not accurate at all (perhaps it failed over time; i'm sure i checked it when I first started using it way back). It always read high, but i did not know that. So I have been running underpressure by as much as 10psi, or more.
I have an ancient radioshack airgauge, that surprisingly also still works, battery still good (not designed to be replaced). I used it to verify which of the gauges was "right", and later used another tester (see below) for comparison to verify.
When i now air up with the rebuilt sears pump, the entire trike rolls FAR EASIER and rides much better and more efficiently. It literlaly feels like I removed glue from all the wheel bearings (which were not touched in this process).
I'm sure part of this is due to the stiffer nature of new tires vs the old thoroughly flexed and softened ones. But the rest is likely the pressure.
So i am going to run experiemnts, just because, and see where the border lies between easy ride and best comfort (bumps, as the tires *are* my suspension).
To that end, and because sometimes I get a slow leak either in a valve core or from a thorn or piece of road debris, even with the thick moped tires and tubes on the rear. (the front wheel doesn't normally have any problems, other than the occasional valve core leakage, and typically lasts perfectly fine from tire install to worn out tread, I decided to try out one of those cheapo TPMS units (on a tenbuck amazon sale),
It does work.
There are six sensors in this set, and the display has two sets of three readouts, one for left and one for right, so I am using hte set of sensors for hte left side right now, wiht the other side taped off so it isn't distracting.
Unforutnatley the six sensor versoin of the device does not have the setup menu at all, whie the four sensor verison apparently does (the manual and other info doesn't say this, but reviews and my own experience show this). So none of the limits can be changed, or the alarm points. all that can be changed is (simultaneously) if it reads in C/F and KPA/PSI. Thankfully hte alarm is in one of my tinnitus bands so i can't hear it so it doens't annoy me.
It is not as accurate as it could be, for the cap sensors. I'd guess the pressures are off on each one by at least 1psi from each other. The temperature on the main unit is close enough to any other thermometer, but the ones int eh cap sensors are perhaps 10F too low on average.
The biggest issue is the leakage. all the caps leak, losing a few PSI over a couple of weeks or less. Today I've temporarily moved the gaskets from each of the three "spare' sensors to the ones I'm using, to doulbe them up and make it easier to get a seal without having to crank them down hard.
this also helps the amoutn of air loss during reinstall after airing up; they have a lot fo travel down onto the stem while htey are letting air out the whole time, before the seal caps off the stem. the extra seal thickness works a fair bit better this way.
The unit is interesting, in that it is internally powered by a little 2.5Ah liithium battery, that is rechraged from a solar cell on the back. it's intended to sit on your dashboard of a car or truck.
The plan, if i keep it on the trike, is to move the solar cell to the top of the trike, while the unit itself stays in the forward part of the canopy where i can look up to see it any time if i want to. It activates on vibration, so i don't need access to any buttons. it does have a usb port for recharge if necessary, but so far it's been going for over a month without an inital charge or a recharge, at two bars on the battery meter.
I also intend to swap out the little flat battery for an 18650 i have from some dead BT speaker; it already has the same plug and it's own BMS board just like the flat battery.
the 18650 is proabbly more capable of handling the temperatures outside in the summer than the flat battery (yes, supposedly the thing is designed to work sitting inside a sealed up car on the dashboard in direct sunlight so it should handle high temps, but i honestly don't believe that they'd use a battery designed for those conditions...and i can use the flat battery in something else that doesnt' need to be outdoors but wont' fit an 18650 inside of. )
