safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
You definitely want the "lip" of the tire because as you go into a lean the "lip" it the last part that holds traction. As the "lip" starts to lose it's grip it does so in a predictable manner. This is one of the reasons that knobby tires are so bad for the street because knobs tend to bend in a turn and the tires then let go without warning. The "lip" gives feedback to the rider and when it does let go it does so slowly.
The other day I was going UPHILL into a left hand turn that crossed over a hump in the middle. I was fully leaned over to the left and was going faster than usual on this stretch of road. The front tire started to slide as the hump unloaded the front end. Once gravity pulled me back down to earth the tire started to catch again and all was fine. The "lip" gave me enough feedback to know that I was in a front wheel slide, but it also recaptured traction without skipping a beat.
The other issue is steering geometry.
You can have a front tire that is simply "too square" and that will make for some bad handling. You want your rear to be a little flatter than your front. Ideally you want the rear to go into a controlled slide before the front starts to slide.
