Hi everyone!
I would like to build my own axial flux coreless motor and I have some questions about the coils and the stator
1- The easiest solution is to build some coils and pour some epoxy over it without any stator slot nor teeth. However I think the cooling must be hard the the magnetic field not so strong as there is no teeth.
2- The second solution I saw was to 3D print a slot so cooling would be better but the magnetic field wouldn't be enhanced by any magnetic teeth.
Then I found this magnetic filament: https://www.proto-pasta.com/products/magnetic-iron-pla
Do you do think it could be a nice solution to combine the ease of use of the second solution and improve the magnetic field with magnetic teeth?
I have no clue how it behaves at high frequency regarding Eddy current losses.
