dnmun said:Pearl street mall. been there 30 years ago, in the exact same spot for Halloween which is way out there too. it gets so steep so fast when you go west it is a totally different type of bike riding. so glad you made it.
grindz145 said:Yeah I went up into the rockies a bit. I honestly don't think they're too bad. Lots of switchbacks.
Doctorbass said:Congrat Troy !!
I'm sure this advanture was awesome! That remember the Justin Cross Canada trip.. like you mentioned. I will watch all your video once I return to home after my work.
This summer I did a 2200km trip with my Zero and DIY range booster pack. I really appreciated the Meanwell to charge faster!
Troy you are awesome! Congrat for the record breaking :wink:
Doc
melodious said:![]()
I recall you had mentioned on your big trip that you were getting front side wobbles (headset?). Could this have been a factor in your front rack failure?
I'm still trying to wrap my head as to how the failed rack locked up the front wheeldown tube break...
veloman said:Oh man, that sucks!
How did the wheel lock up? Did the rack go all the way around?
Thud said:Ouchers!
Epic end to an epic adventure......prolly more fitting end to an old solder....went out with his boots on or something to that effect.
Did you get banged up at all?
dogman said:Better the frame than your collarbones. That's one of my bigger fears when riding around 100+ miles from home, a frame issue that bad. Incredible it never happened till you got back to your hometown.
jkbrigman said:Troy, dude, you overcoming the bad luck you run into just makes you more badass man. It's inspiring to those of us who have similarly bad luck.
jkbrigman said:I hope, someday, to ride an ebike in your direction and shake your hand. Then sit down and have some actual as-God-intended Buffalo Wings with something from Southern Tier, Troegs or Ommegang. From where I'm sitting, that's 660 miles and 14,000 feet of cumulative climbing.![]()
Makes me wonder if a mid-drive is a better choice than a hubmotor for that kind of riding....
grindz145 said:whelp. In an ironic twist of fate, I pretty much destroyed my frame today on the way home. My front rack came loose suddenly, lodged itself into the wheel, locking it up, and sending me over the bars.... this was the aftermath:
http://instagram.com/p/sf3dQRtk5Q/
jkbrigman said:Troy - thought I'd ask, since no one has yet:
You have the two meanwells mounted on your bike, plus you carried the air-breathing charger. Do you consider the meanwells one of your successes of the ride? What about the air breather?
