jkbrigman
Don't you guys mean the shunt in the CONTROLLER? Everyone keeps saying shunt in the Cycle Analyst, but it's in the controller, right?
And: Is it possible to leave the charger/power supply connected while you run the bike or does that screw up the shunt? (seems like it would mess up the shunt...)
A cool solution would be to add a connector and switch to the aluminum case of the controller, then you could leave the charger connected and just work the switch to charge?
Maybe even just add only the connector, then exchange the main switch for the controller to a three-position switch that would be "charge - off - run"....
